noob question...
hello everyone.im new to this site and recently bought my 1st accord,its a 91 4dr 5sp..my question:my third gear is pretty much shot(from previous owner)jumps out off gear when i let out the clutch,does this mean i should get a new tranny or rebuild,im pretty sure its the syncro?im looking for the cheapest route,im just using it as a beater and soon im going to attempt to drive it from ct. to fl.....also i have one rim on it and three stellies.what other stock wheels will fit,i.e. other hondas/acuras?im looking for either one more steelie or 3 rims that match my one rim i was told its from a 98-00? accord?i dont know but im doing my research on it so i know more about accords now...lol.thanks.
-keith-
-keith-
well i guess from what i was told it just went out,but,he said he raced it a few times after it went out.but all the other gears seem fine and go into gear fine.so im thinking just rebuild,or find another used but good cond. one.
also, i was wondering what if any other trannys will bolt up to my block?its a f22a4.
thanks for the help.
-keith-
-keith-
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1hot4dr »</TD></TR><TR><TD CLASS="quote">also i have one rim on it and three stellies.what other stock wheels will fit,i.e. other hondas/acuras?im looking for either one more steelie or 3 rims that match my one rim i was told its from a 98-00? accord?i dont know but im doing my research on it so i know more about accords now...lol.thanks.
-keith-</TD></TR></TABLE>
Any Honda 4 bolt pattern 4x114.3mm wheel will fit. That encompasses all 4cyl Accords from the 1990 model year to 2002, and Preludes from 1992 to end of production
P
P
He will have either the f22a1, a4 or a6 varient of the 2.2L SOHC non-Vtec; depending on Model series (DX,LX EX and SE) for the 1991 model year.
The trans will be a cable controlled Manual transmission with a hydralically controlled clutch.
He is correct, he has an issue with the third gear cluster and syncro ring assembly. I also suspect the shift fork's worn since he complains of it popping out of gear.
P
P
yeah the motor is the f22a4 ex.i did some researching on the wheel issue and found what you said,any wheel with the 4x114.3 bolt pattern will fit,which is 90-00+ accord and the prelude 92+.the clutch seems fine,i drove it about 45-1hr. and the clutch grabbed each gear fine.i found a used but good cond. tranny for 250$ so i should be fine for now.thanks for all of your help guys,i really appreaciate it.
-keith-
-keith-
