vehicle speed sensor for sir cluster install?
what pin do i connect the vss signal wire to the ecu? then whitch one do i use to send it to the cluster
that how to site was helpful but doesn not go indepth about the vss
everything else works except the spedo
please help me
please help me
"To install the VSS you must Split the signal wire connected to the Electronic VSS. Run one wire into pin A11 connected to the back of the guage cluster and the other wire into pin B16 in the ECU. This is the pin location for the vehicle speed amplifier. You will have to ground the ground wire and splice the power wire into an switched power source in the car. The Blk/Yel and Yel wires for the cluster will work fine"
http://faq.ef-honda.com/index....ng=en
gl
gl
USDMSiR
15
Aug 31, 2006 02:07 PM
