Suspension & Brakes Theory, alignment, spring rates....
Gc suspentions
Old Feb 13, 2006 | 09:03 PM
2DoorBandit's Avatar
Default Gc suspentions
im thinking of going with GC/Koni yellows. with rates around 430f/380 rear(car will be daily dirven and occausly drag raced(not on the street) i would like to get rid of the gap between the spring and the sock mount when susention is at full drop so i was thinking of getting the extended top hat and the koni yellow that neuspeed offers sine that koni has a shorter rod length what do u guys think about that...im kinda anoob to suspetion so dont be too harsh
Old Feb 13, 2006 | 09:05 PM
slammed_93_hatch's Avatar
Default Re: Gc suspentions (2DoorBandit)
the top hats will help, but getting the nuespeed konis wont.
id suggest getting 8 inch springs, and some helper springs.
GC will know what your talking about when you call and order.
Old Feb 14, 2006 | 12:38 PM
Default Re: Gc suspentions (slammed_93_hatch)
if there is a gap betwwen the spring and the top mount will that give you a bad ride
Old Feb 14, 2006 | 01:01 PM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2DoorBandit &raquo;</TD></TR><TR><TD CLASS="quote">if there is a gap betwwen the spring and the top mount will that give you a bad ride</TD></TR></TABLE>
The only time there should be a gap between the spring and the tophat would be when the car is in the air. I'm not sure what you're trying to get at...
Old Feb 14, 2006 | 02:26 PM
Default Re: Gc suspentions (AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">
there was a gap betwwen my frineds and it gave him a horrible ride it was super bouncy...or maybe that was because the struts were blown think that was it
Old Feb 14, 2006 | 02:30 PM
Tyson's Avatar
having a gap when the car is at full droop doesnt affect the ride at all. if he was using some kind of adjustable spring kit with stock shocks, that alone will cause horrible ride. if you have a swaybar, then both front or rear wheels will need to be in air at the same time for it to even have a gap, which would mean youre doing some kind of jump, not likely...
also, the neuspeed koni yellows dont have a short rod length, just have an internal spacer that limits droop. effectively the same thing only in regards to droop, but not the same in any other aspect like being less likely to internally bottom out.
extended top hats would certainly reduce droop length as well if thats what you really want. but its not going to change your ride unless youre already hitting your bumpstops.
offdeline
Suspension & Brakes
15
Nov 9, 2008 02:22 PM
bbhockey19
Dec 28, 2006 07:54 PM
hawjboi
Suspension & Brakes
Jan 26, 2006 02:30 PM
allmotorgsrekk
20
Dec 29, 2004 10:55 PM
mamaboy
Jul 7, 2003 07:45 PM
