12:1 compression
Old Feb 13, 2006 | 07:09 PM
pulpdeem's Avatar
Default 12:1 compression
is it possible to reach 12:1 compression on a jdm r motor with just a thinner head gasket?
what is the highest compression possible with just a head gasket and who makes it?
Old Feb 13, 2006 | 07:10 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: 12:1 compression (pulpdeem)
http://www.c-speedracing.com
go to the how-to's and then to compression calculator
Old Feb 13, 2006 | 11:04 PM
92TypeR's Avatar
FSAE
Default Re: 12:1 compression (Evs-One)
With a thinner headgasket + decked block and milled head = yes.
Just a thinner headgasket, no.
Old Feb 13, 2006 | 11:07 PM
itr1244's Avatar
Default Re: 12:1 compression (92TypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">With a thinner headgasket + decked block and milled head = yes.
Just a thinner headgasket, no.</TD></TR></TABLE>
thinner headgasket .. no way
i think it will still be hard to get 12 : 1 comp R with milled head.
i think you need CTR pistons to make it around 12:1 and oviously there are many other pistons to choose from
Old Feb 14, 2006 | 04:46 AM
ITR-00-1457's Avatar
why do you want to go that high anyway? you are just going to get detonation with pump gas and ruin a perfectly good motor. i know i did it, even with a good tune. your best bet is to keep it under 11.8:1. as far as a head gasket I always go with Cometic. http://www.cometic.com
Old Feb 14, 2006 | 05:07 AM
totsie7944's Avatar
Default Re: 12:1 compression (ITR-00-1457)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR-00-1457 &raquo;</TD></TR><TR><TD CLASS="quote">why do you want to go that high anyway? you are just going to get detonation with pump gas and ruin a perfectly good motor. i know i did it, even with a good tune. your best bet is to keep it under 11.8:1. as far as a head gasket I always go with Cometic. http://www.cometic.com</TD></TR></TABLE>
not true at all.... whoever tuned your car probably wasn't a great tuner.
I have been running 12:1 for 2 years now and after tuning with even bigger cams I have no detonation problems.
As for getting there, I just say go with CTR pistons....
Old Feb 14, 2006 | 07:32 AM
92TypeR's Avatar
FSAE
Default Re: 12:1 compression (totsie7944)
I'm running 12.3:1 and 36degrees of ignition timing at WOT on 92 octane with huge cams. With these cams (BC5) I could run 13.5:1 on 92 and be fine. Remember that the larger the overlap on the cam, the more compression is bled off.
It is all about the tune. If you cannot tune ignition timing you will have problems.
ProjectBB6
Mar 13, 2008 09:24 AM
CXtypeR
Dec 9, 2006 03:05 AM
Jun 26, 2004 08:51 PM
prdtr15
Sep 25, 2003 03:45 PM
