Random misfire question???
Old Feb 13, 2006 | 06:43 PM
drtyhatch's Avatar
Default Random misfire question???
Just a quick question... i recently changed my cap and button and when i pulled the old cap off, the spring in the coil was caught on the little bolt on the inside of the cap, well now the spring is bent a little and i tried to straighten it out but i couldn't get it quite right. Car has never EVER had a misfire before this point. I will also add that timing belt, water pump, all oil seals and valve adjustment was just done aswell (AT ACURA). Now at IDLE the car will run perfect for a few minutes and then a misfire and then it will run fine again after the single misfire, I have replaced, plugs, cap and rotor, and i have NOLOGY wires. You guys have any suggestions, could that spring cause this?
Juans_MX3
10
Apr 21, 2011 05:17 PM
D@9 A.D.B.
Jun 30, 2008 04:22 PM
menappi
14
Jun 26, 2006 05:36 PM
drtyhatch
Feb 14, 2006 06:59 PM
