to those with 11/12:1 compression
Old Feb 13, 2006 | 06:05 PM
93h22a1vtec's Avatar
Default to those with 11/12:1 compression
What kind of numbers do you get when you do a compression test?
Old Feb 13, 2006 | 06:08 PM
2lude4u's Avatar
Default Re: to those with 11/12:1 compression (93h22a1vtec)
With an 11:1 H22 at close to sea level I got 225-230 psi.
Old Feb 13, 2006 | 06:09 PM
Default Re: to those with 11/12:1 compression (2lude4u)
wat cams and what temperature and is that with stock pistons?
Old Feb 13, 2006 | 06:11 PM
Honda Sport's Avatar
same question here. I'm pushing out 265-270 across(in seattle area, not sure what the elevation is here) on my JDM h22a(came out of an auto ). I've been trying to figure out what compression ratio I have cause supposedly, these numbers are high for a stock motor. (I'm still on stock internals).
Old Feb 13, 2006 | 06:20 PM
2lude4u's Avatar
Default Re: (Honda Sport)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93h22a1vtec &raquo;</TD></TR><TR><TD CLASS="quote">wat cams and what temperature and is that with stock pistons?</TD></TR></TABLE>
I have Crower stage 3's so they probably drop the compression #'s a little bit due to some overlap. Cams with no overlap (like stock) might be around 240 psi I guess. The tests were done with a warm engine, jdm block with flat valve faced valves, & a slightly milled head.
Old Feb 13, 2006 | 06:25 PM
Default Re: (2lude4u)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lude4u &raquo;</TD></TR><TR><TD CLASS="quote">
I have Crower stage 3's so they probably drop the compression #'s a little bit due to some overlap. Cams with no overlap (like stock) might be around 240 psi I guess. The tests were done with a warm engine, jdm block with flat valve faced valves, & a slightly milled head.</TD></TR></TABLE>\
pm sent
PirateMcFred's Avatar
My old H22 with type-S pistons and cams was at ~240 psi at 500' elevation. But it varies depending on what compression tester you use. More/longer hose affects the PSI reading and cams drop the pressure too.
Pirate
Old Feb 14, 2006 | 09:58 AM
bump
Old Feb 14, 2006 | 10:36 AM
mgags7's Avatar
dude compression test psi are not something to estimate your ratio with, they vary too much....its just like a dyno, you cant compare across manufacturers....
the only thing a compression test should show is consistent numbers....
nokturnal_munkeeboy
Jul 23, 2006 08:50 PM
sikciv666
May 22, 2004 07:06 AM
bxsi
Apr 2, 2004 05:42 AM
blufke
11
Dec 30, 2003 09:07 AM
Modifiedinteg
Oct 29, 2003 06:46 AM
