Tq specs on ARP head studs...???
Old Feb 13, 2006 | 05:26 PM
spec_v_kid's Avatar
Default Tq specs on ARP head studs...???
putting a turbo gsr together, wonder whats the tq specs you guys use on ARP head studs w. their lubs....
Old Feb 13, 2006 | 06:17 PM
zman's Avatar
Default Re: Tq specs on ARP head studs...??? (spec_v_kid)
65 ft/lbs with ARP moly lube
80 ft/lbs with 30wt engine oil
Old Feb 14, 2006 | 05:25 PM
spec_v_kid's Avatar
Default Re: Tq specs on ARP head studs...??? (zman)
any1 else??
thanks for the info
Old Feb 14, 2006 | 05:48 PM
non-VTEC's Avatar
i thought it was 70ft/lbs with moly lube?
Old Feb 14, 2006 | 05:55 PM
80884's Avatar
Default Re: Tq specs on ARP head studs...??? (non-VTEC)
I did 90 ft/lbs with moly, oh wait...thats for 1/2" studs,
Old Feb 14, 2006 | 08:18 PM
spec_v_kid's Avatar
Default Re: Tq specs on ARP head studs...??? (80884)
so...
Old Feb 15, 2006 | 06:17 PM
spec_v_kid's Avatar
no one else?? little help will be great
Old Feb 15, 2006 | 08:57 PM
spec_v_kid's Avatar
x1
Old Feb 15, 2006 | 09:33 PM
vaporboy12's Avatar
i did 70ftq the first time then when i put a new headgasket on i went to 72ftq both using moly
Old Feb 18, 2006 | 06:04 PM
b20vtechatch
Guest
Posts: n/a
Default Re: Tq specs on ARP head studs...??? (vaporboy12)
how about a b18a1
Old Feb 18, 2006 | 07:09 PM
HamiltonRex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zman &raquo;</TD></TR><TR><TD CLASS="quote">65 ft/lbs with ARP moly lube
80 ft/lbs with 30wt engine oil</TD></TR></TABLE>
This guy knows his ****.
Old Feb 18, 2006 | 08:10 PM
92gsrteg's Avatar
Default Re: Tq specs on ARP head studs...??? (HamiltonRex)
zmans right, i did 72 on my gsr with moly just for assurance, no problems. this is a high compression jdm gsr with .043" thick cometic hg and ive been runnin 10psi daily for 3.5 months now. stil strong
Old Feb 19, 2006 | 10:36 AM
dandizel's Avatar
Default Re: Tq specs on ARP head studs...??? (92gsrteg)
If you buy the ARP's new, there will be a paper in the box telling you what ft pound to torque too. on my d16a6 headstuds, if i remember correctly, was 60ft pounds.
Old Feb 19, 2006 | 10:51 AM
stinker504's Avatar
Default Re: Tq specs on ARP head studs...??? (dandizel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dandizel &raquo;</TD></TR><TR><TD CLASS="quote">If you buy the ARP's new, there will be a paper in the box telling you what ft pound to torque too. on my d16a6 headstuds, if i remember correctly, was 60ft pounds.</TD></TR></TABLE>
I just picked up some H23 ones and they say to torque them down to 80 ftlbs.
Old Feb 19, 2006 | 10:55 AM
beerbongskickass's Avatar
Default Re: Tq specs on ARP head studs...??? (stinker504)
The torque specs are right on the box or on a little piece of paper in the box.
Old Feb 19, 2006 | 11:05 AM
92cxturbo's Avatar
Default Re: Tq specs on ARP head studs...??? (beerbongskickass)
70ft pounds. Thats what it says on the paper I have for gsr's.
Old Mar 4, 2006 | 10:18 AM
KiddEng's Avatar
Default Re: Tq specs on ARP head studs...??? (92cxturbo)
*i don't mean to thread jack, but while on the topic of tq specs and arp's,
i know when installing new arp head studs, you should re-tq them after 10 heat cycles or 1000 miles...etc somthing to that effect.
my question is with re-using arp's, after getting my head rebuilt, new hg and put back together, would i need to open it up and re-tq the studs after the 10/1000 cycle? or is re-tq only apply to new headstuds?
*to the OP, the shop who put together my setup used 70ft lbs with moly lube on itr.
avotegra
Dec 27, 2015 01:26 PM
allhonda
Mar 23, 2009 07:05 PM
boost and bass
Aug 15, 2008 06:55 PM
eRACING
Aug 15, 2004 08:19 PM
saso
Jun 3, 2002 02:57 PM
