PLEASE GUYS I NEED THE WIREING FOR OBD0 TO OBD1!!!!!!!!!
Alrighty guys, i am about to be doing my obd1 conversion but cant find the wiring and stuff.
I need all the wiring to be done for a 89 crx si.
i got a boomslang conversion harness on its way.
I need like for the dizzy, and if the alt wires are diff and how to undo the resistor box's on the injectors, please help guys
please
me
please
me
its just one resistor box and its located on top of the d/s strut tower... its prety small but its silver and has ridges on it...
make sure if you take it out you are running an obd1 ecu *AND OBD1 FUEL INJECTORS!*
ok,yeah i have y8 injectors
where would be a good place to get the dist jumpers,or should i just kinda make my own,i have a spare obd0 dizzy
if so anyone have the wireing for that
rywire...
jsut got my rywire in the mail today and ive always heard really good things about them but i was really supprised with the quality.
for rywire
for rywire
also, you can do the obd1 conversion without running obd1 injectors. You could just keep your stock injectors w/ the resistor box...it's really just up to you. As for the distributor jumper harness, if you want to keep it simple, just order one off rywire.com Otherwise, you can just cut/solder/shrinkwrap an obd1 plug into your wiring harness. Check out this graph. Match the #'s in the picture. The other plug is simple, has 2 wires going to it, and they are the same color
the dizzy i have is missing one plug so i think i might just hardwire it in for now them when i switch to the other dizzy i will put the plugs on
92hatchattack
Aug 23, 2004 11:15 PM
