weird electrical problem, need help!
Old Feb 13, 2006 | 12:33 PM
TheDelSlo's Avatar
Default weird electrical problem, need help!
i have a 90 crx dx, i noticed yesterday that when i step on my brakes, all 3 brakelights don't light up and the seatbelt and door light flash on the dashboard while i'm holding the pedal down, the bulbs aren't blown, can anyone help me out on this? thanks
Old Feb 13, 2006 | 12:54 PM
Perfectionist's Avatar
Default Re: weird electrical problem, need help! (TheDelSlo)
Bad connections somewhere. Check the harness at the rear hatch area that feeds the brake lamps. Probably got corrosion in the connectors.
Old Feb 13, 2006 | 01:03 PM
pwrofdrm's Avatar
Default Re: weird electrical problem, need help! (Perfectionist)
that would cause the weird problems with the lights flashing in the dash?
Old Feb 13, 2006 | 02:51 PM
NosCivic01's Avatar
check your fuses.. does your horn work? if not you blew the fuse then you have to worry bout the harness having a short somewhere goodluck
Old Feb 13, 2006 | 02:52 PM
Boosted Chemist's Avatar
Default Re: (NosCivic01)
did u resently install a radio or someother mod?
Old Feb 13, 2006 | 03:01 PM
TheDelSlo's Avatar
the harness pulled outta the plug for the horn, is it possible that the wires touched and popped something, i noticed it a day or so ago.
i still don't see how a popped fuse will make the lights in the cluster flash when i'm on the brakes.
Old Feb 13, 2006 | 03:14 PM
ludesrv's Avatar
Well I dunno about EFs but my Prelude if the fuse is blown or the light itself is blown the brake light comes on in the dash. And if it's low on brake fluid, same situation. I dunno.
Old Feb 13, 2006 | 05:02 PM
NosCivic01's Avatar
yes first fix that harness for the horn and replace the fuse for horn/brake good to go
Neticz
Oct 24, 2015 12:18 PM
wakenbake215
Honda Civic (2006 - 2015)
Feb 8, 2012 07:45 AM
Cowtownchick
Jul 29, 2007 08:34 PM
Sassafrass
11
Sep 4, 2003 01:18 PM
