how do fix gas leak on my I/M ?
Old Feb 13, 2006 | 12:17 PM
philosofy1's Avatar
Default how do fix gas leak on my I/M ?
recently i noticed on my 93 hatch (B16A) i would smell gas when i first started the car until it was warmed to running temp. today i decide to pop the hood to put some window washing fluid and noticed there was fuel on the intake manifold, right underneath the injectors. seems like they are leaking. i didn't know that they can leak! does this mean i need to replace just the seals around them? and if so are they expensive?
Old Feb 13, 2006 | 12:20 PM
postman's Avatar
Default Re: how do fix gas leak on my I/M ? (philosofy1)
you cn just replace the o-ring on them. did you take them out before. anytime injector is removed should replace these
Old Feb 13, 2006 | 12:26 PM
philosofy1's Avatar
Default Re: how do fix gas leak on my I/M ? (postman)
actually yes, but that was about 8 months ago. i had to move the fuel rail to get to pcv valve so i can replace it.
Old Feb 13, 2006 | 12:36 PM
TK-4004's Avatar
there are little rubber 0-ring gaskets that go between the injectors and the manifold. they are easy to replace and not too expensive. just be careful not to tear them when putting the new ones in. good luck.
Old Feb 13, 2006 | 12:42 PM
philosofy1's Avatar
Default Re: how do fix gas leak on my I/M ? (TK-4004)
thanks! i'll be working on it tomorrow, wish me luck
Old Feb 13, 2006 | 12:45 PM
fms1day's Avatar
Finished my swap and fuel leaked somewhere on the I/M... found out it was one of the injectors, so I swapped the old fuel rail/injectors over from the old motor. Fixed the problem. So it must be something that's injectors related.
Old Feb 13, 2006 | 01:05 PM
philosofy1's Avatar
Default Re: how do fix gas leak on my I/M ? (fms1day)
all four are leaking. there is a small brown stain underneath them. i did remove them in the past. i change my rings first - it's chaeper.
thanks for the advice though!
Dylan29
Jun 17, 2018 10:01 PM
kaspa35
Jul 24, 2008 02:36 PM
kelviiv
Feb 25, 2008 06:04 AM
Ronin150
Jul 18, 2005 01:40 PM
I Want An Si
Dec 27, 2003 07:51 PM
