remote start wiring questions
Old Feb 13, 2006 | 11:47 AM
egcivic611's Avatar
Default remote start wiring questions
I'm trying to hook up my remote start...there is a wire that says:
Pin 4: Blue/White wire: (-) 200ma bypass output when remote start. Connect this wire to the interface of remote start bypass module.
Can anyone explain to me what this means...I dont have a clue..thanks
Old Feb 13, 2006 | 11:59 AM
B18C_EJ8's Avatar
That wire supplies a low current ground which is generally used to activate an immobilizer bypass unit such as a 556U etc...
Old Feb 13, 2006 | 12:02 PM
egcivic611's Avatar
Default Re: (B18C_EJ8)
I have no idea what that means...sorry
I just need to know what exactly to hook it up to...
Old Feb 13, 2006 | 12:19 PM
B18C_EJ8's Avatar
Don't know how much simpler I can make it... That wire gets hooked to the status input of the immobilizer bypass module.
What kind of car are you installing the remote start on? Year Make Model please.
Old Feb 13, 2006 | 12:22 PM
egcivic611's Avatar
92 honda civic
Old Feb 13, 2006 | 12:24 PM
egcivic611's Avatar
Default Re: (egcivic611)
what is the "status input of the immobilizer bypass module"?
Old Feb 13, 2006 | 12:30 PM
B18C_EJ8's Avatar
Don't even worry about it then. Your car does not have an immobilizer, therefore, you do not need to do anything with the blue/white status wire.
Old Feb 13, 2006 | 12:33 PM
egcivic611's Avatar
okay thanks
Old Feb 13, 2006 | 12:41 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Don't even worry about it then. Your car does not have an immobilizer, therefore, you do not need to do anything with the blue/white status wire.</TD></TR></TABLE> Unless the 92 is a 5 speed, [standard trans.] 94
Old Feb 14, 2006 | 07:26 AM
IHateJDM's Avatar
Default Re: (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Unless the 92 is a 5 speed, [standard trans.] 94</TD></TR></TABLE>
the clutch switch is not an immobilizer.
Old Feb 14, 2006 | 10:30 AM
fcm's Avatar
fcm
Old Fart
Default Re: (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">
the clutch switch is not an immobilizer.</TD></TR></TABLE> No kidding, I could have sworn it "immobilizes" the starter.
Maybe we only connect the wire to the "Clutch Interlock Switch", [starter relay side] so the car will remotely start, kind of pointless if you have to get into car and step on clutch to start it with the remote start, or are you just one of the guys that think bypassing the "CIS" completely is the best way to do that? 94
Old Feb 14, 2006 | 10:43 AM
IHateJDM's Avatar
Default Re: (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> No kidding, I could have sworn it "immobilizes" the starter.
Maybe we only connect the wire to the "Clutch Interlock Switch", [starter relay side] so the car will remotely start, kind of pointless if you have to get into car and step on clutch to start it with the remote start, or are you just one of the guys that think bypassing the "CIS" completely is the best way to do that? 94</TD></TR></TABLE>
an immobilizer is factory security, a clutch switch is a safety feature, not security. And it doesn't matter which way you wire up the clutch switch, the remote start will function the same either way.
Old Feb 14, 2006 | 12:09 PM
fcm's Avatar
fcm
Old Fart
an immobilizer is factory security, a clutch switch is a safety feature, not security. And it doesn't matter which way you wire up the clutch switch, the remote start will function the same either way.</TD></TR></TABLE> Well daa, it's not security, its a safety, you learn something new every day, Also......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote"> And it doesn't matter which way you wire up the clutch switch, the remote start will function the same either way.</TD></TR></TABLE> tell me more, I was also pretty sure it did matter how it was wired, could I have been wrong all these years? 94
Old Feb 14, 2006 | 12:37 PM
IHateJDM's Avatar
Default Re: (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> tell me more, I was also pretty sure it did matter how it was wired, could I have been wrong all these years? 94</TD></TR></TABLE>
either way the car will remote start without you in it, and either way it'll still jump if left in gear.
Old Feb 14, 2006 | 01:22 PM
fcm's Avatar
fcm
Old Fart
either way the car will remote start without you in it, and either way it'll still jump if left in gear. </TD></TR></TABLE>Well first, if you use a remote start for a manual transmission, then it's not going to start in gear.
Your also not telling me how the "CIS" can be wired "any which way" and still work, allowing you to remotely start the car 94
Old Feb 14, 2006 | 01:27 PM
IHateJDM's Avatar
Default Re: (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">Well first, if you use a remote start for a manual transmission, then it's not going to start in gear.
Your also not telling me how the "CIS" can be wired "any which way" and still work, allowing you to remotely start the car 94</TD></TR></TABLE>
it will try to start in gear, the car will jump forward and stall. And I thought you understood that we were comparing wiring the switch the way you described vs just bypassing it entirely.
DOMAN!EJ8
Audio / Security / Video
Dec 21, 2012 09:46 PM
edcantu9
Oct 23, 2011 06:07 PM
TheMuffinMan
Mar 9, 2009 03:11 PM
kinick313
May 5, 2007 09:36 AM
FourthGenHatch
Nov 28, 2002 02:28 PM
