B18 going into EG, what power steering bracket needed to run power steering pump?
Just wondering as I've searched for this and couldn't find anything about this but I'm going to be putting in my b18 into my eg/ej and I want to run my power steering with this swap.
what bracket will bolt onto the b-series that will run my d-series pump?
the stock one won't work
thanks
thanks
what stock one? stock b-series or stock d-series?
the b-series should work.my 93 civic is a dx, did my swap from a front clip, both had power steering and it was a straight bolt on, no modification.
My swap is a b18a...so it never came with power steering in the integra that it was from.
My question is what b-series bracket can I use to run power steering on my car. I know the stock d-series power steering bracket that holds the pump won't bolt onto the b-series engine.
for some reason i remember looking at the pumps and noticing they were the same. as for the brackets i don't remember? i don't see why the d-series would not. but for some reason i am wrong, then the b-series one would surely fit. like i said, when i did my swap it was a direct bolt on (B16A in a 93 civic). i didn't even remove the pump from the motor.
but what pump are you talking about? by saying you didn't remove the pump from the motor I'm guessing you were using the b16 power steering pump/bracket... so your using the b16 p/s pump. Or are you saying that you used the d-series p/s pump/bracket
I've tried to use the D-series bracket on my friends b-series engine to bolt on the power steering pump and it didnt line up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeunreal2 »</TD></TR><TR><TD CLASS="quote">who the hell needs power steering?
I do, because I want it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner »</TD></TR><TR><TD CLASS="quote">Nevermind, found my answer
94+ integra power steering bracket is what I need
thanks
</TD></TR></TABLE>thanks
I have a b18b in my 94 EG. THE MOTOR came with power steering however the stock EG power steering line did not mount/fit the pump. So I swapped the pumps from my old D15B7 and it works. The belt is a little loose but it works..
swatteamtimmah
Feb 2, 2006 10:51 PM
hb_guy
Oct 20, 2005 11:07 AM
