wth is grinding when i turn left?
It only grinds when I make a left hand turn it sounds
like its coming from suspension? I have no idea I took the
wheel off and didn't see anything wrong. Any ideas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmpremonition »</TD></TR><TR><TD CLASS="quote">It only grinds when I make a left hand turn it sounds
is the car lowered ? what type of wheels are on the vehicle ? could just be rubbing, also could be wheel bearings/joints.
</TD></TR></TABLE>is the car lowered ? what type of wheels are on the vehicle ? could just be rubbing, also could be wheel bearings/joints.
more than likely the wheel bearings have you hit a curb at all or ran over anything. if it were the wheels and suspension it should rub when you turn right also since everything would be the same all around but if its just when you turn left have the bearings checked thats more than likely the problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tabrisakakaoru »</TD></TR><TR><TD CLASS="quote"> Right CV joint.
I was going to say CV Joint too...mine was making the same noise!
</TD></TR></TABLE>I was going to say CV Joint too...mine was making the same noise!
Joshua_Honda
Suspension & Brakes
Apr 10, 2007 12:23 PM
