help on jdm b16a starter ASAP!!
What kind of starter will fit on a jdm B16a.
It has the stock transmission with it also.
I tried a 94 integra starter, it looks the same but one bolt is more to the top and the pinion gear is too short to engage the flywheel.
NEED HELP FAST!!!!
NEED HELP FAST!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CALIdelsolSIR »</TD></TR><TR><TD CLASS="quote">try a 99-00 civic si (b16) starter. Or also try a DOHC VTEC Del Sol Starter. Both will bolt right up.
bump for a answer above!!
</TD></TR></TABLE>bump for a answer above!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects »</TD></TR><TR><TD CLASS="quote">all b series starters should be the same. sounds like you might have a single cam starter</TD></TR></TABLE>
actually, i heard that the b18c is different then the b16. Not sure where i heard it, but definately try and go with a standard b16 starter if you can.
DoubleURX
Aug 8, 2006 02:58 PM
SuicideSlide
Feb 15, 2005 09:10 AM
