Can I replace my 4 speed manual tranny with a 5 speed manual
I have a 91 civic 4 speed transmission. I also have a 91 w/5 speed, both manual transmission. I have two questions:
1). Can I just replace the 4 speed with my 5 speed tranny? Both are same engines, 1.5
2). Will the half shafts from my 5 speed fit in the 4 speed tranny?
A 5-speed transmission from any '88-91 Civic or CRX is a bolt-in replacement, and your current axles will work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondaisok »</TD></TR><TR><TD CLASS="quote">Would I have to switch the flywheel also?</TD></TR></TABLE>
no
no
I saw somewhere mentioned that I would have to change the hubs from my 5 speed to match the 5 speed axle and transmission. Is this true or can I just put the 5 speed and 5 speed axles in my 91 hatchback w/4 speed transmission?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondaisok »</TD></TR><TR><TD CLASS="quote">I saw somewhere mentioned that I would have to change the hubs from my 5 speed to match the 5 speed axle and transmission. Is this true or can I just put the 5 speed and 5 speed axles in my 91 hatchback w/4 speed transmission?</TD></TR></TABLE>
only if you doing a b series swap
As jlicrx said, you re-use the axles you already had from the 4-speed transmission - they will work with the 5-speed tranny. If you use the 5-speed axles, then you will have to to change to the DX/LX/Si or EX hubs, because the hub end of the 5-speed axle is different than the 4-speed axle.
take the 4 speed out, put the 5 speed in, they are the same externally, everything from the 4 speed will work with the 5 speed. NOW GET WORKIN!
Thanks. That was what I was looking for. I have a bad cv joint in my 4 speed hatchback. I wanted to replace the cv shaft with one from my 5 speed that I'm getting ready to strip down, but it looks like I would have to switch the hubs also, on both sides to match.
How difficult is it to switch the hubs?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondaisok »</TD></TR><TR><TD CLASS="quote">Thanks. That was what I was looking for. I have a bad cv joint in my 4 speed hatchback. I wanted to replace the cv shaft with one from my 5 speed that I'm getting ready to strip down, but it looks like I would have to switch the hubs also, on both sides to match.
How difficult is it to switch the hubs?</TD></TR></TABLE>
"Swapping the hubs" really involves swapping the entire knuckles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9ZC »</TD></TR><TR><TD CLASS="quote">do you have to cut the slot for the 5th gear is it there already, sorry for thread stealing i just am doing same thing in like couple days</TD></TR></TABLE>
There is no "slot" for the shifter; it is not gated. The internals of the transmission determine the shift pattern.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9ZC »</TD></TR><TR><TD CLASS="quote">thanks never know until u ask or take things apart ;o)</TD></TR></TABLE>
civicbizz253
Aug 30, 2017 04:22 AM
