Death by freezing temps?
Old Feb 13, 2006 | 04:06 AM
fireslinge's Avatar
Default Death by freezing temps?
Hey guys, i went to start my car this morning and all i got was a clicking noise. I though t it was out of gas so i put an extra gallon in to see if that would fix anything (didnt help). The tempature is below 20 here, feels like much less. Im wondering if i have a frozen gasline or something. Any diagnosis help would be apreciated.
Old Feb 13, 2006 | 04:52 AM
championshipwhite93si's Avatar
Default Re: Death by freezing temps? (fireslinge)
battery. mine just clicks when its dead. try jumping it or replacing the battery. more than likely you have eough charge in it to have your lights on and even your door dinger probably works, but its not got enough in it to turn over the car. try that first. be sure to clean your battery terminals too
Old Feb 13, 2006 | 05:03 AM
syntax.'s Avatar
roll start it and pop the clutch. sometimes that works when my battery is very cold. Or you can take out the battery at night and leave it somewhere warm.
be careful jump starting a frozen battery, they can burst.
Old Feb 13, 2006 | 05:07 AM
The Weather Man's Avatar
Default Re: Death by freezing temps? (championshipwhite93si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by championshipwhite93si &raquo;</TD></TR><TR><TD CLASS="quote">battery. mine just clicks when its dead. try jumping it or replacing the battery. more than likely you have eough charge in it to have your lights on and even your door dinger probably works, but its not got enough in it to turn over the car. try that first. be sure to clean your battery terminals too</TD></TR></TABLE>
Yep. The starter is getting just enough to activate the solenoid - but not enough amperage to do anything else. It requires a lot of amps to start a car. Just try to jump it - you can jump the starter if you want.
Old Feb 13, 2006 | 04:48 PM
fireslinge's Avatar
jumped and it works.... thanks guys
Old Feb 13, 2006 | 08:30 PM
ed_1's Avatar
It also has to do with the cold cranking amps.
tlsole
Jan 14, 2010 07:35 AM
CBS2000
Honda S2000
11
Apr 13, 2006 03:58 PM
JDM_Type-R
Dec 4, 2004 12:20 PM
4DRmafia
24
Jun 25, 2004 05:59 PM
vizsual00
Aug 11, 2003 11:48 AM
