Please help!! *********What Pistons in my B17A..********
Old Feb 12, 2006 | 11:36 PM
WhiteLightening's Avatar
Default Please help!! *********What Pistons in my B17A..********
Hey guys, I need some help on what pistons i should put in my B17A. The engine currrently has I/H/E, cams, most bolt ons. I popped my headgasket last summer and I am slowly rebuilding for spring. I was thinking about going with usdm ITR pistons, or jdm B16A pistons. I have heard that the itr psitons may be a problem in the B17A........I really just want my car to be reliable so would the B16A pistons be a safer choice? Any advice is appreciated.
Old Feb 13, 2006 | 08:25 AM
Does anybody have even a slight clue.....???
Old Feb 13, 2006 | 04:33 PM
Sam92Teg's Avatar
Default Re: (WhiteLightening)
Need to know what cams you have, you just say 'cams', not much help. Is there a compression ratio goal? Help us help you.
Old Feb 13, 2006 | 04:40 PM
CALIdelsolSIR's Avatar
Default Re: (Sam92Teg)
if you are just going for reliability, i think itr's should be fine (if there are no compression issues) how many miles does the engine have on it ? are you doing a complete bottom end rebuild ? what rings what rods ?
Old Feb 13, 2006 | 04:46 PM
v-tec maz's Avatar
Default Re: (CALIdelsolSIR)
sell you b16 block and get a 1.8 liter. its a waste of money if you dont do this.
Old Feb 13, 2006 | 04:53 PM
Default Re: (v-tec maz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v-tec maz &raquo;</TD></TR><TR><TD CLASS="quote">sell you b16 block and get a 1.8 liter. its a waste of money if you dont do this.</TD></TR></TABLE>
b16 hater ... B16B Kisses and wipes a B18C *** !!!
for you
Old Feb 19, 2006 | 03:17 PM
I am running Buddy spec III+ cams w/ buddy club cam gears, Cat Cams valve springs/ titanium retainers. ITR intake manifold, BBK 70mm TB.
Stock compression on B17A is 9.7:1 I want to bump it up to around 10.4:1, i guess thats just in between the compression of B16A and ITR. I don't want anything too crazy I want to keep stock rods with some OEM honda pistons but i just don't know if the itr pistons in my B17A will bump my compression too much..?
Old Feb 19, 2006 | 03:19 PM
Anybody know if the wrist pins of the ITR sit lower on the piston than B16/B17????
blackeg
21
Jan 4, 2012 04:16 PM
DAchiko
Aug 31, 2007 01:34 PM
WhiteLightening
Feb 13, 2006 03:26 PM
shomershavis
Aug 28, 2004 01:20 AM
ysrhatch
Aug 24, 2001 06:28 PM
