FS 1995 integra gsr 2 door so cal
SOLD!
SOLD!
for 7000!~ on autotrader
may be willing to trade for a 2000 or higher honda civic , no swapped engine and must be clean and clean title. and paid off for with title in hand.
prefer auto but manual is ok otherwise just cash.
nothing older thans 2000
PRICE is 7000 firm, updated in autotrader
dont ask if you dont have the money
Price will be reduced as I start taking off parts and selling them.
Price is 7,000 with updated in autotrader
All the parts on the car is orginal not swapped out like other integras etc.. except for the b16 tranny lsd which has the legit tranny vin/sticker. everything is good to go. original interior. 2nd owner original miles.
cage can be removed and put back to stock, i still have the rear seat etc..
VIN avail upon request
I also have the car fax, and will help transfer title over at AAA.
I will have the car smogged before sale so you can use that to transfer the title.
I have the title to the car in HAND
PICS avail upon request
Reason for sale: want a new car and a 4 door.
PRkiller from redlinetrackevents.com can vouch for performance since he drove the car before recently
car is street/smog legal have all the carb stickers for intake/headers/cams etc. etc. car was built to be street /smog legal.
NOOOO TRADES!!!!!!!!!!!!
When i was shopping for integras last year they were hard to come by and the ones that were available were all salvaged title or look like crap.
If you dont have the cash please dont bother
1995 Black Integra gsr 2 door manual tranny
mileage 123,000
Clean Title
2nd owner Bought car with 120,000 on it
original motor/car.
I am willing to part out some of the parts like :
picked up prices and they have less 3000 miles on them bought last year but now im going a different route and selling car
Exterior
- car was repainted stock original black paint job is just ok, high high end but it was repainted and looks good no rust or faded paint
- Rear body kit/lip
- Side lips
- Side body kit/rear brake vents
- Shaved rear spoiler, rear antenna, side moldings
- Rear aftermarket lights
- S2000 antenna
Suspension
- braided brake lines front and rear
- stock suspension
- Custom Roll bar /cage 4 point Cro moly welded by L-Con racing
- Rear trunk bar
- 4 17 inch 5zigen wheels with kuhmo new tires.
- 4 spare 14 inch stock steelies with very used tires
- Energy suspension motor mount inserts all 3 ,
- Replaced all motor mounts also with OEM motor mounts have some extra mounts also
Engine
- Stock oem 95 gsr motor
- Stock working AC all intact
- ITR Cold air intake with carb sticker
- Gsr OEM ported Throttle body by MAXBORE from Honda tech
- Skunk2 Intake manifold with carb sticker installed with extended bolts for hondata gasket
- Hondata Intake manifold gasket
- Skunk 2 Stage 1 cams Professionally installed by mechanic and valve adjusted to skunk2 specs
- AEM pulleys
- Hondata s100 Tuned by church auto dyno at 191 hp / 137 torque
- Msd spark plug wires
- New distributor by distributor king less than 3,000 miles
- New clutch installed professionally and act pro lite fly wheel brand new installed
- B16 tranny with Cusco LSD
Interior
- Pioneer mp3/cd unit with remote controls
- Razo shift ****
- Red stitched shift boot
- Sparco grip pedals drilled in not the clamp on kind
- Rear seats are out because of cage but I still have the rear seat/top/bottom/rear cargo cover and everything if you want to get cage removed and put back in. the plastic panels are still in car.
Maintenance:
- timing belt replaced
- tranny fluid replaced with redline
- new clutch and fly wheel Lite fly wheel
- new brake pads and rotors just done 3/13/06
- new distributor put on car last year.
- new motor mounts and inserts.
- flushed all fluids, radiator, brake.
- AC /PS all intact OE stuff
- new headlight bulbs
- new battery
- all new belts
- new spark plugs
- msd wires
- rear main seal and cam seals replaced when cams installed and valves adjusted by mechanic
Everything on car came with car it wasnt put in and swapped out like other integras youll see.
SECURITY
also car comes with an alarm
and LO jack
I have receipts for most of the items and the services
- timing belt was changed
- radiator fluid, tranny fluid, brake fluid all changed /flushed.
- new spark plugs
car does not come with autometer tach. and is on stock suspension
Modified by hondatech2000 at 12:45 PM 3/26/2006
Modified by hondatech2000 at 7:44 PM 4/2/2006
Modified by hondatech2000 at 8:40 PM 4/3/2006
Modified by hondatech2000 at 9:51 PM 4/3/2006
Modified by hondatech2000 at 7:41 PM 4/4/2006
Modified by hondatech2000 at 6:45 PM 4/7/2006
Modified by hondatech2000 at 9:18 AM 4/8/2006
SOLD!
mileage 123,000
Clean Title
original motor/car.
Exterior
- Rear body kit/lip
- Side lips
- S2000 antenna
Suspension
- stock suspension
- Rear trunk bar
Engine
- AEM pulleys
Interior
- Razo shift ****
Maintenance:
- new battery
- all new belts
- new spark plugs
- msd wires
SECURITY
and LO jack
- new spark plugs
These car's are cheaper:
http://losangeles.craigslist.o....html
or this one:
Modified by newtothis at 9:13 AM 2/14/2006
or this one:
