15X6" steelies ? What car?
Anyone know where I can source out some 15X6" steelies? Looking for the blackout/hubcap type. I know the EP SI has 15X4" steelies but any 6 or 7 inchers out there in a 4x100? I dont care what car they will come from, as long as they are cheap and will fit my civic
Thanks for any help guys.
ok so Im answering my own questions as I go along so thanks to me!! haha
Scion xA and Scion xB Specifications:
Bolt Pattern
4x100
Center Bore
54.1mm
Nut Size
M12x1.5
Stock Wheels/Tires
15"x5.5" +38 offset / 195/60-15 xB 185/60/15 xA
37 lbs per wheel & tire
Bolt Pattern
4x100
Center Bore
54.1mm
Nut Size
M12x1.5
Stock Wheels/Tires
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aallbbeerrtttttt »</TD></TR><TR><TD CLASS="quote">
there is no way a car has 15"x4" steelies..my damn corolla had 14x5.5</TD></TR></TABLE>
33555 001 1 DISK, WHEEL (15X4T) NO COLOR 146.58 109.94 Qty:
got it from the honda site, I think its right, that is damn small though !!
i seriously doubt there are any 4" wide wheels out there. maybe the festiva with its 12" rim. the ep3 hatches dont come with steelies. most 15" steelies you will find are about 6" wide at least
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by James Bond »</TD></TR><TR><TD CLASS="quote">33555 001 1 DISK, WHEEL (15X4T) NO COLOR 146.58 109.94 Qty:
I don't think that means 4 inches wide. I can't think of a car with 15x6 steel wheels in a 4x100 bolt pattern.
</TD></TR></TABLE>I don't think that means 4 inches wide. I can't think of a car with 15x6 steel wheels in a 4x100 bolt pattern.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTI »</TD></TR><TR><TD CLASS="quote">
I don't think that means 4 inches wide. I can't think of a car with 15x6 steel wheels in a 4x100 bolt pattern.</TD></TR></TABLE>
Bolt Pattern
4x100
Center Bore
54.1mm
Nut Size
M12x1.5
Stock Wheels/Tires
Looks like that is as close as it will get, thats fine to run a 205 though so Im gonna find some of those. the XB guys sell them for like 50 bucks for all four too
Bolt Pattern
4x100
Center Bore
54.1mm
Nut Size
M12x1.5
Stock Wheels/Tires
thats for the spare tire.. hence it being 4" wide..
the 01-02 civic ex comes with 15x6 steelies..
</TD></TR></TABLE>thats for the spare tire.. hence it being 4" wide..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kyden »</TD></TR><TR><TD CLASS="quote">
Cool ill add that to my search too!
Some people want 250.00 for steelies HAHAH wow only 250?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by James Bond »</TD></TR><TR><TD CLASS="quote">Scion xA and Scion xB Specifications:
Bolt Pattern
4x100
Center Bore
54.1mm
Nut Size
M12x1.5
Stock Wheels/Tires
They won't fit over the Civic's hub. Civic wheels have a 56.1 mm center bore...
Bolt Pattern
4x100
Center Bore
54.1mm
Nut Size
M12x1.5
Stock Wheels/Tires
</TD></TR></TABLE>They won't fit over the Civic's hub. Civic wheels have a 56.1 mm center bore...
here you go: http://www.discounttiredirect....83&tp=
i bought some for mounting my RAce tires on, good stuff and great prices.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SonicGSR98 »</TD></TR><TR><TD CLASS="quote">here you go: http://www.discounttiredirect....83&tp=
There are two problems with those wheels.
1. They are not hubcentric. In other words, the center bore of the wheel (that's the big hole in the very middle) is not designed to just fit perfectly around the part of the hub that protrudes around the axle nut. So only the lugs center the wheel. This can cause vibrations, which many people have with lugcentric wheels (although many others). This is why many wheel sellers explicitly recommend against using such wheels except with winter tires.
2. At $45 for 15x6 with 4x100 lug pattern, they're more expensive than you can get brand new Honda brand steel wheels for. For example, you can look up wheels for a 2004 Honda Civic on the website for San Leandro Honda (4 door LX manual trans), go to the section for CHASSIS and WHEEL DISKS, and you will see that they sell the stock black 15x6 steel wheels (part number 42700-S5D-A21) for $40.53 each. They're even less - $37.52 - from Majestic Honda. EDIT - I CHANGED THE PART NUMBER FROM PREVIOUSLY, SORRY
Granted, Discount Tire offers free shipping, which probably makes the price similar - but I would sure rather use Honda wheels designed with the proper center bore to fit over the hub, than to use wheels with a center bore that's too big and might vibrate.
Modified by nsxtasy at 11:23 PM 2/24/2006
</TD></TR></TABLE>There are two problems with those wheels.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy »</TD></TR><TR><TD CLASS="quote">There are two problems with those wheels.
2. At $45 for 15x6 with 4x100 lug pattern, they're more expensive than you can get brand new Honda brand steel wheels for. For example, you can look up wheels for a 2004 Honda Civic on the website for San Leandro Honda (most models), go to the section for CHASSIS and WHEEL DISKS, and you will see that they sell the stock black 15x6 steel wheels (part number 42700-S5D-901 or 42700-S5D-911, I'm not sure what the difference is) for under $40 each.
Granted, Discount Tire offers free shipping, which probably makes the price similar - but I would sure rather use Honda wheels designed with the proper center bore to fit over the hub, than to use wheels with a center bore that's too big and might vibrate.</TD></TR></TABLE>
good points, I didn't have a chance to lookup the price of the OEM wheels. I personally never had any vibration problems with those wheels. All-in-all, it comes down to personal preference.
