My car surges?
Old Feb 12, 2006 | 08:19 PM
Rebel_67's Avatar
Default My car surges?
I have a crx with a 92 ls swap and i just cleaned the throttle body and when i turn it on it it goes to like 3 grand and drops to like 15-18 grand and it doesnt stop doing it. I was told it was my Throttle position sensor but i changed that to day and it is still doing it? Can any body help me out?
Old Feb 12, 2006 | 10:52 PM
nObOdy65's Avatar
wow, youre engine can really rev high.
Try your IACV. idle air control valve, either clean it or replace it.
Old Feb 12, 2006 | 11:48 PM
watsvtecEK's Avatar
Default Re: (nObOdy65)
Try to adjust the throttle cable? maybe reset the ecu?
Old Feb 12, 2006 | 11:58 PM
Sack Master's Avatar
Default Re: (D 2da A9)
There are 2 holes in your throttle body. One leads to the AIC and the other to the FITV(I'm guessing FITV because you said you just cleaned your TB). Get the car to operating temp and then stick your finger over the hole and see which one makes your idle level out. If plugging one of these makes your car idle normal then you know where your problem is. I think the top hole goes to the AIC and the bottom to the FITV. If neither of them do anything then it's probably a vacuum leak somewhere else. Look for missing vacuum lines or spray starter fluid in spots on your intake manifold until you hear the idle raise. That's my good deed for the month so don't ask me for any more help . Someone else can tell you how to fix it.
Old Feb 13, 2006 | 05:15 AM
Rebel_67's Avatar
Default Re: (Sack Master)
well i tried what Sack master said and when i would cover up the bottom hole(which is the FITV) it would stop so i guess i figured it out. I Aprectiate all of yalls advice thanks so much.
crxnonvtec
22
Sep 3, 2009 02:52 PM
GroundZer0 336
Mar 31, 2005 07:34 PM
FatBoy4door
Oct 20, 2004 09:17 PM
Ink00
Dec 24, 2002 01:15 AM
FourthGenHatch
Apr 29, 2002 11:08 AM
