Steering Column
I was just wondering if you can put the adjustable steering column from a 95 civic ex on a 93 cx hatch. The steering column on my 93 hatch is not adjustable and I was just curious if it would fit.
same family of cars it will mount up however because the ex comes with power steering the diameter of the shaft where it connects to the steering column is different so just make sure you use the joint from your origional column and you whould be fine.
freakasis
13
Jul 21, 2005 09:52 AM
