Suspension & Brakes Theory, alignment, spring rates....
strut tower bars
Old Feb 12, 2006 | 05:36 PM
coronadrinker's Avatar
Default strut tower bars
Can somebody tell me what diameter tubing your strut tower bars are made of, and what brand it is. Thanks And lower rear tie bars too if you guys don't mind.
Old Feb 12, 2006 | 05:38 PM
And post some pics if you guys have some time thanks
Old Feb 14, 2006 | 03:55 PM
Default Re: (coronadrinker)
anybody?
Old Feb 15, 2006 | 10:02 AM
PIC Performance's Avatar
Default Re: strut tower bars (coronadrinker)
For your future reference, both strut tower bars and tie bars are going to be more or less useless for our Hondas.
Old Feb 15, 2006 | 02:48 PM
voltronR34's Avatar
Default Re: strut tower bars (PIC Performance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PIC Performance &raquo;</TD></TR><TR><TD CLASS="quote">For your future reference, both strut tower bars and tie bars are going to be more or less useless for our Hondas.</TD></TR></TABLE>
Why is that?
Old Feb 15, 2006 | 03:42 PM
Default Re: strut tower bars (voltronR34)
The way they connect in the places that they do don't do anything noticeable to reduce the flexing of the chassis.
Even if they did, there's a laundry list of suspension and chassis mods to do before you would have to consider adding these bars. Springs, shocks, swaybars, tires, rotors, pads, bushings, motor mounts, cage, corner balance, track time, track time, track time and track time.
Old Feb 15, 2006 | 04:24 PM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by voltronR34 &raquo;</TD></TR><TR><TD CLASS="quote">
Why is that? </TD></TR></TABLE>
Because the 'chassis flex' that everyone is so concerned about eliminating is torsional flex that happens between the front and rear axles in the passenger area; not on the centerline of the mounting points.
Old Feb 16, 2006 | 05:37 AM
f22abuilder's Avatar
Default Re: strut tower bars (AutoXer)
i got the neuspeed upper front strut bar along with sway bars on bottom fr/bk...
i have 17 rims with **** tires and there is a huge differance in suspension..and handling...its a good start.. but there are a lot of factors for your apllication
Old Feb 16, 2006 | 02:49 PM
Default Re: strut tower bars (f22abuilder)
so does anybody have an answer?
Old Feb 16, 2006 | 03:48 PM
SiRay13's Avatar
I use skunk2 strutbars and lower tie bar, it makes a huge difference through the corners. the strut bars are not cylendrical from skunk2, but they're about 2.5" wide and 3/4 deep.. im guessing the tie bar is probably just over 1.5" at the widest point.
Vtec04
Suspension & Brakes
Oct 29, 2017 11:16 AM
maal15
Nov 7, 2008 03:41 PM
Zavy
Suspension & Brakes
Apr 14, 2008 02:46 AM
ITR607
Oct 27, 2001 02:37 PM
