pulling and installing energy bushings??
Old Feb 12, 2006 | 05:08 PM
JDM_EK_JOE's Avatar
Default pulling and installing energy bushings??
If i had access to a press just press down on the centre of the bushing where the metal is or do I need to lube it??? If I cant get access to a press is it possible???
I bought Robs. Tein SS and I dont want to install them until I do new front & rear LCA's
Old Feb 12, 2006 | 05:10 PM
jdmboxrocket's Avatar
Default Re: pulling and installing energy bushings?? (91Civic_Joe)
you can cut them out with a torch, but your best bet is to take to a machine shop.
Old Feb 12, 2006 | 05:20 PM
JDM_EK_JOE's Avatar
Default Re: pulling and installing energy bushings?? (jdmboxrocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboxrocket &raquo;</TD></TR><TR><TD CLASS="quote">you can cut them out with a torch, but your best bet is to take to a machine shop.
Wouldnt the rubber start melting? And also I need a torch. Do i need to buy the whole welding machine or is there little tanks like those little propane tanks???
Old Feb 12, 2006 | 05:24 PM
Pee Wee's Avatar
you can get a small torch for under $20 at a hardware store
Old Feb 12, 2006 | 05:29 PM
eda6's Avatar
i did mine w/o a torch or a hydro press.
for removal-you'll need a vise, rent a ball joint press, pb blaster, various sockets. Use the sockets to press out the old bushings.
to install-grease them up, install the poly and then the sleeve. Use a c-clamp and washers to press the bushing in.
Old Feb 12, 2006 | 05:33 PM
JDM_EK_JOE's Avatar
Default Re: pulling and installing energy bushings?? (eda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">i did mine w/o a torch or a press.
to install-grease them up, install the poly and then the sleeve. Use a c-clamp and washers to press the bushing in. </TD></TR></TABLE>
Whats a PB blaster.
Old Feb 12, 2006 | 05:36 PM
Pee Wee's Avatar
stuff in a can that get rusty bolts off and other crap. $5 at autozone
12three
Suspension & Brakes
12
Apr 6, 2011 11:38 AM
hybrid90
Jan 22, 2008 03:31 PM
jonnydbagz
Jun 15, 2007 03:42 PM
blaze_125
May 24, 2007 11:26 AM
aserenehope
Dec 7, 2006 02:27 PM
