91 Integra Rs need electrical help badd
ok so today i swap out the tan underdash centerconsole plastic and the door panels for black ones because im starting to do a interior conversion fomr tan to black so then i get into my car to leave and go somewhere and i my hatch light, door light, clock, radio are flickering on and off and my interior light dont even work and the radio wont play ...checked all the fuses and they were good, i didnt even mess with the electrical at all because i dont have PW or PL ....what could be wrong ?????pleeeeze any help would be amazing
I wouldn't say it's a short, more like an open. But I think the issue is that one of your ground wire is loose, that's why the lights are flickering. I would look and see if you notice any ground wires that's not firmly secure to the chassis. You might have had to disconnect it when you remove the underpanel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drift2004 »</TD></TR><TR><TD CLASS="quote">short, i had the same problem u need a ground, try a ground from the battery to the chassis of the car </TD></TR></TABLE> isnt there already one of those
Modified by 91IntegraX at 1:00 PM 2/13/2006
ok i went and crawled around under my dash for a bit...i found the relay that click and it stops clicking when i unplug it..but all the lighs still blink and nothing works,.does it need to be replaced or is it something else
Modified by 91IntegraX at 7:01 PM 2/13/2006
90civicbns
Jul 7, 2013 04:17 AM
Canadian_EF
Aug 15, 2010 11:07 PM
