15" or 16" size wheels on type r?
Old Feb 12, 2006 | 01:27 PM
doggydog's Avatar
Default 15" or 16" size wheels on type r?
This will on daily driven car. Do you guys recommened sticking to 15' wheel or going to 16" wheel? I will probabbly try some track racing in future and no I do not plan on going with bigger caliper, other than those that come stock with car. I plan on using 205/50 -15 tires.TIA guys.
Old Feb 12, 2006 | 01:56 PM
RTW DC2R's Avatar
both are fine, personal preference and doesnt matter much for daily driving.
16" will give you slightly better tire options for the track if you dont have a dedicated track wheel already.
Old Feb 12, 2006 | 04:32 PM
Chris F's Avatar
Default Re: (RTW DC2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R &raquo;</TD></TR><TR><TD CLASS="quote">16" will give you slightly better tire options for the track if you dont have a dedicated track wheel already.</TD></TR></TABLE>
16 has fewer choices in R compound tires that fit (205/45, 215/45, etc.)
-Chris
Old Feb 12, 2006 | 04:38 PM
Chris F's Avatar
Default Re: (Chris F)
for instance,
205/45 R16 at Tire Rack: 4 Choices.
Hoosier A3S05, R3S05, Rain tire, and Ecsta V700
215/45 R16 at Tire Rack: No tires
205/50 R15 at Tire Rack: 15 Choices
Avon Tech R heat cycled
Avon Tech R
Avon Tech R-A
BFG Drag Radial
Hoosier R3S05
Kumho Ecsta V710
Kumho Victoracer V700 heat cycled
Michelin Pilot Sport Cup Heat cycled
Yokohama A032R Hard
Yokohama A032R Soft
Yokohama A048
Old Feb 12, 2006 | 05:34 PM
nsxtasy's Avatar
H-T Order of Merit
Yes, you have a lot more tire choices for 15" wheels (I assume you mean 15 inches even though you said 15 feet ). In addition to those Chris mentioned, you have the Toyo RA-1 track tire in 205/50-15, and the Falken Azenis RT-615 in the same size. The RT-615 doesn't come out in 215/45-16 until the end of the year. You also have a lot more choices of street tires in 15" (195/55-15 as well as 205/50-15), and they're usually less expensive than 16" tires.
Old Feb 12, 2006 | 09:20 PM
Itr001's Avatar
Default Re: 15" or 16" size wheels on type r? (doggydog)
15's look okay, but 16's with low profile tires fill the gap better and look niceR
Old Feb 12, 2006 | 09:40 PM
B7AudiA4's Avatar
Default Re: 15" or 16" size wheels on type r? (Itr001)
17's look nicer
but I'd choose 16 over 15s anyday.
It really doesn't matter on daily driving.
Weight difference may though. SO yeah
Old Feb 12, 2006 | 10:09 PM
Haleiwa-Brando's Avatar
Default Re: 15" or 16" size wheels on type r? (FutureITR)
I've had 15's, 16's, and 17's on my R. By far the 16's I feel are the best compromise.
Modified by Haleiwa-Brando at 1:49 AM 2/13/2006
Old Feb 12, 2006 | 11:02 PM
Bbasso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Itr001 &raquo;</TD></TR><TR><TD CLASS="quote"> 16's with low profile tires fill the gap better and look niceR</TD></TR></TABLE>
Ya right...
If you are keeping the diameter the same as stock (which is 23.5") then there will not be any difference in the wheel gap to the fender...
Get your info straight before posting.
Old Feb 13, 2006 | 01:43 AM
B7AudiA4's Avatar
Default Re: 15" or 16" size wheels on type r? (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">
Ya right...
Get your info straight before posting.</TD></TR></TABLE>
thinking the samething
Old Feb 13, 2006 | 01:50 AM
JjuuN R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Itr001 &raquo;</TD></TR><TR><TD CLASS="quote">15's look okay, but 16's with low profile tires fill the gap better and look niceR</TD></TR></TABLE>
dumbest thing i've read all week
Old Feb 13, 2006 | 10:12 AM
Itr001's Avatar
This goes to the last three stupid post's on top of me. I NEVER SAID THE GAP FROM TIRE TO FENDER. If you get 16's the wheel well will be filled more nicely then it would with 15's because the rim is bigeR. You even said it, its your daily driver, its not like the 15's are going to make a difference so you might as well get what looks betteR
Old Feb 13, 2006 | 10:41 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Itr001 &raquo;</TD></TR><TR><TD CLASS="quote">You even said it, its your daily driver, its not like the 15's are going to make a difference so you might as well get...</TD></TR></TABLE>
...what costs le$$:
Yokohama ES100 195/55-15 $61
Yokohama ES100 205/45-16 $82
Kumho Ecsta SPT 195/55-15 $63
Kumho Ecsta SPT 205/45-16 $74
Toyo T1-R 195/55-15 $84
Toyo T1-R 205/45-16 $103
Falken Azenis RT-615 205/50-15 $78
Falken Azenis RT-615 215/45-16 not yet available
Old Feb 13, 2006 | 10:47 AM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Itr001 &raquo;</TD></TR><TR><TD CLASS="quote">This goes to the last three stupid post's on top of me. I NEVER SAID THE GAP FROM TIRE TO FENDER. If you get 16's the wheel well will be filled more nicely then it would with 15's because the rim is bigeR. You even said it, its your daily driver, its not like the 15's are going to make a difference so you might as well get what looks betteR</TD></TR></TABLE>
Old Feb 13, 2006 | 10:49 AM
Chris F's Avatar
Default Re: 15" or 16" size wheels on type r? (Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">
That's NOT what he said Reid. Don't you get it?
Old Feb 13, 2006 | 11:06 AM
The Tech-1's Avatar
Default Re: 15" or 16" size wheels on type r? (Chris F)
Wow.
Old Feb 13, 2006 | 04:07 PM
itr1244's Avatar
Default Re: 15" or 16" size wheels on type r? (The Tech-1)
haha .
ok when u look at the tire size
205 / 50 / 15
sidewall: 4.0 "
radius : 11.5 "
diameter :23.1 "
215 / 45 / 16
S.W : 3.8 "
R : 11.8 "
D : 23.6 "
so if you look at the diameter of the tire from center of your wheel hub
15" = 11.5"
16" = 11.8"
so that's not really filling up the gap ..
if you wanna fill up the gap you can just get taller sidewall tires..
what you just said there just dont make any sence
Old Feb 13, 2006 | 04:08 PM
doggydog's Avatar
Thanks to everyone who took time to reply to my question. Apparently I will be going with 16" wheels.Thanks again.
Old Feb 13, 2006 | 04:10 PM
itr1244's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Itr001 &raquo;</TD></TR><TR><TD CLASS="quote">This goes to the last three stupid post's on top of me. I NEVER SAID THE GAP FROM TIRE TO FENDER. If you get 16's the wheel well will be filled more nicely then it would with 15's because the rim is bigeR. You even said it, its your daily driver, its not like the 15's are going to make a difference so you might as well get what looks betteR </TD></TR></TABLE>
wheel well is under the fender
gap from tire to fender = wheel well gap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doggydog &raquo;</TD></TR><TR><TD CLASS="quote">Thanks to everyone who took time to reply to my question. Apparently I will be going with 16" wheels.Thanks again.</TD></TR></TABLE>
all you want is the appearance?
just get 20" bling blings.. that looks better
Old Feb 13, 2006 | 04:17 PM
JjuuN R's Avatar
lol, what a clown
Old Feb 13, 2006 | 04:26 PM
white rocket's Avatar
Default Re: 15" or 16" size wheels on type r? (itr1244)
Huh, this thread took a turn for the worst .
When shopping for new rims I found that a 15x7 size gave me more tire options; hence the 15x7 ce28's I roll on now . I've played the 17inch game and it wasn't for me
Do you have stock suspension? That will play a role in comfort. With my Tein coils and 17's and a 40 series tire the ride was complete ***. However when I switched to 15's and a 50 series the ride improved, mainly over sharper bumps. Then there is the wheel weight to consider. Are you concerned with that factor?
As of today, if I was in your boat, I would go with the Enkei RPF-1 in 16x7. Lightweight, classic style and just an all-around nice rim. Good for the street and track.
Old Feb 13, 2006 | 04:55 PM
Itr001's Avatar
damn you people must be on sum good shyt to be this lost. With 16's you see MORE of the FUCKEN RIM then you do with 15's. Does your stupid *** not understand that concept, did i put it in terms you could finally understand?? DO you not understand why people get bigger rims? You can post back whatever you want because im not going to respond to this thread anymore since the person who started it already got what he needed
Old Feb 13, 2006 | 05:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Itr001 &raquo;</TD></TR><TR><TD CLASS="quote">damn you people must be on sum good shyt to be this lost. With 16's you see MORE of the FUCKEN RIM then you do with 15's. Does your stupid *** not understand that concept, did i put it in terms you could finally understand?? DO you not understand why people get bigger rims? You can post back whatever you want because im not going to respond to this thread anymore since the person who started it already got what he needed</TD></TR></TABLE>
You may not respond but I'm quite sure you will read the future comments. I'm not siding with you or the other boys. Though I'll tell you that for the most part, the people that make up the ITR forum are very analytical so if you happen to missword something, chances are, someone will call it out.
You said 'fill the gap'. It's right there plain as day. Though this is not what you meant as you explained in your quote, it isn't what you said. All I can say is don't sweat it. We're all ******* and idiots every now and then.
Heck I have my own real life spell checker Chris F.
Old Feb 13, 2006 | 05:37 PM
Chris F's Avatar
Default Re: 15" or 16" size wheels on type r? (Haleiwa-Brando)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">missword</TD></TR></TABLE>
misword
Old Feb 13, 2006 | 05:46 PM
itrsport.com's Avatar
At times I wished H-T functioned like the TV show Survivor.
