How do you slide the timing belt on? (jdm h22a)
Old Feb 12, 2006 | 01:23 PM
DarkBB4's Avatar
Default How do you slide the timing belt on? (jdm h22a)
hey the motor is out of the car and it has a manual tensioner.. but i cant seem to slide the timing belt on.. IS there a trick to this?
Old Feb 12, 2006 | 01:26 PM
4bidden's Avatar
Default Re: How do you slide the timing belt on? (DarkBB4)
Its a very tight fit. Make sure the tensioner is all the way backed off and the cam gears are perfectly aligned. Do the intake side first.
Old Feb 12, 2006 | 01:43 PM
LudeyKrus's Avatar
Keep the belt slid mostly off all the pulleys and get it on ALL pulleys before sliding it all the way on.
Also, a bud showed me a trick where you loosen the tensioner and push down on where the spring connects to take up the slack, pushing it all the way loose. Doing this made it MUCH easier for me to get the belt back on.
Old Feb 13, 2006 | 06:40 PM
CGags13's Avatar
Default Re: (LudeyKrus)
^^^Exactly what i did..worked the best of any other technique
JDM-h22a
Feb 7, 2012 01:12 PM
withoutlimitslude
Jul 19, 2010 02:58 PM
orangeaccord
Jul 11, 2009 03:05 PM
HYBRID_H@TCH
Jun 25, 2003 12:35 PM
GraphiteAccord
Apr 24, 2002 09:26 PM
