question about skunk 2 pro 1's
Does it require an aftermarket valvetrain or will a itr valvetrain be suitable for it? Also what compression ratio is recommended for it? thanks
I believe the pro 1's have the same specs/a little more aggressive than the old skunk2 stage 2's, so an upgraded valve train would be needed
also to get the most out of the cams you will have to up the compression ratio. i believe skunk2 said anything over 11.5:1 would be fine for the old stage 2's
boy_hapon
Aug 25, 2005 07:24 AM
b16vtecsol
Feb 23, 2004 08:09 PM
