please help map problems on an obd1 crx
Old Feb 12, 2006 | 12:00 PM
flatblackhatch's Avatar
Default please help map problems on an obd1 crx
ok i just did my swap and when i fired it up it would rev but wouldnt idle. then i switched the trs plug with the map plug and it would idle but wouldnt rev. So i put it back to how it suppose to be and the car wont start it has fuel and has spark. When you try to start it it will fire and die. Then after bout 30 seconds of trying to start it it lets out a cloud of white smoke from the intake. i have a obd1 crvtec with a b16 head. im using a obd0 throttle body so there is no map on it. but however i am using a map out of a 89 crx dx and i have a 88 hf could this be the problem one being mphf and the other dphf please help this is my first swap i have done if you have any questions ill gladly answer please help
Old Feb 12, 2006 | 03:04 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: please help map problems on an obd1 crx (flatblackhatch)
sounds like your cam timing is off by some teeth, recheck it
Old Feb 14, 2006 | 02:07 PM
Default Re: please help map problems on an obd1 crx (HondaPartsHero)
just rechecked the teeth and its on all marks match up i dont know what to do
bswappedej1
Oct 21, 2011 09:32 PM
1SLWEJ1
Feb 24, 2011 01:46 PM
ihaterust
Jul 21, 2006 03:53 PM
SVOboy
May 22, 2006 03:42 PM
gsrswapdcivic
Sep 27, 2005 02:31 AM
