T25 on a b16
Old Feb 12, 2006 | 11:41 AM
EJ8 GSR-T's Avatar
Default T25 on a b16
I am putting a b16 in my civic and i am going to do pistons and rods, but i have a turbo kit for it, but it has a DSM t25 turbo which i know is a bit small for the b16. i had it on my stock d series but threw a rod (probably due to boost spike), but if i had forged pistons and rods, would i have a prob with this turbo on my b16? I know a bigger turbo is better but my bill for the b16 and parts/ install is getting bigger and bigger so i simply cant afford a new turbo now, but a bit down the road i plan to upgrade to an EVO3 (keepin it dsm so i can keep manifold and dp same). So more or less do you think a DSM T25 will cause damage to forged pistons and rods at like 12 psi?
Old Feb 12, 2006 | 11:51 AM
I Have an STD's Avatar
wrenchin'
Default Re: T25 on a b16 (userdead626)
t25=waste of time 16g=waste of time. dont be ghetto, buy a real turbo. even a 42/48 garrett will be more fun that those two turbos. i have a 48/60 on my b16 and its wonderful. spools real quick and pull hard to 8k RPM.
btw, u dont need to build the motor for 12 psi. just have the car tuned right.
Old Feb 12, 2006 | 11:53 AM
EJ8 GSR-T's Avatar
Default Re: T25 on a b16 (I Have an STD)
ya i know, but thing is that i plan on putting a larget turbo in within the next few months, my goal is 350ish hp, but at the same time i need the car asap becuase its my only car, so i was just going to put the t25 in more or less to fill the gap....until i can afford a larger turbo...
Old Feb 12, 2006 | 11:55 AM
wrenchin'
no, put the motor in the car and drive it. when u can afford to turbo the car the RIGHT way, then do it once and do it right. click on the link in my sig to see my build. its done CHEAP and done well
Old Feb 12, 2006 | 12:16 PM
EJ8 GSR-T's Avatar
well see i cant wait, i need the car, and i if i put the 8.5:1 comp. pistons in it and no turbo it will run like ****....i just want to know if the small t25 will do damage to the engine? i know the power will not be great, but better than n/a
Old Feb 12, 2006 | 12:17 PM
EJ8 GSR-T's Avatar
and i will not run boost on a stock motor ever again, i know a million people do and have no prob but i had bad luck with my d and i will not repeat that
Old Feb 12, 2006 | 12:50 PM
91civicDXdude's Avatar
the t25 will not damage the engine any worse than the tune will allow.
btw, a 16g is generally bigger than a .42/.48 T3. Hell a 14B is about the same size as a 42/48
Old Feb 12, 2006 | 01:05 PM
wrenchin'
Default Re: (91civicDXdude)
the car will run fine with 8:5:1 compression, it will just be slow, no big deal
Old Feb 12, 2006 | 02:05 PM
EJ8 GSR-T's Avatar
[QUOTE=91civicDXdude]the t25 will not damage the engine any worse than the tune will allow.
QUOTE] what do ya mean by that?
Old Feb 12, 2006 | 02:55 PM
EJ8 GSR-T's Avatar
Default Re: (userdead626)
Old Feb 12, 2006 | 03:14 PM
wrenchin'
he means if you have it tuned shitty, it will hurt your motor. if you have it tuned well, it wont hurt your motor
Old Feb 12, 2006 | 03:26 PM
EJ8 GSR-T's Avatar
Default Re: (I Have an STD)
how exactly do you know if its tuned well, what are the signes to look for?
Modified by userdead626 at 6:58 PM 2/12/2006
Old Feb 12, 2006 | 05:36 PM
wrenchin'
you need to HAVE IT TUNED. please tell me you know that that means
Old Feb 12, 2006 | 05:50 PM
EJ8 GSR-T's Avatar
Yeah, lol i do, but with my d series i though i had it tuned correctly, obviously i did not.....so how do i know if its a good tune?
00CivicSi5spd
Sep 27, 2017 05:59 PM
jdmekrobot
Mar 11, 2009 04:34 PM
siRk-oz
Feb 22, 2008 08:02 AM
x still jaded x
Mar 24, 2006 05:51 AM
