b18b crankshaft into a b18c block = more POWER & TORQUE?
Old Feb 12, 2006 | 11:29 AM
GSRpoweredEJ's Avatar
Default b18b crankshaft into a b18c block = more POWER & TORQUE?
Is anyone here smart enough to give me tips on rebuilding a GSR block using a crankshaft from an Integra LS?
Old Feb 12, 2006 | 12:27 PM
rdblckSV650S's Avatar
Default Re: b18b crankshaft into a b18c block = more POWER & TORQUE? (GSRpoweredEJ)
if you search on it i believe there's some other threads on this.
But from what i loosely know, you'd have to rework the oil squirters because they would get hit by the long stroke. And your deck height would be insufficient with the longer stroke. Also, increasing the stroke lowers your safe redline. You're better off just building the GSR internals.
Old Feb 12, 2006 | 01:07 PM
shermanyang's Avatar
Default Re: b18b crankshaft into a b18c block = more POWER & TORQUE? (slvrblckf4i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slvrblckf4i &raquo;</TD></TR><TR><TD CLASS="quote">if you search on it i believe there's some other threads on this.
But from what i loosely know, you'd have to rework the oil squirters because they would get hit by the long stroke. And your deck height would be insufficient with the longer stroke. Also, increasing the stroke lowers your safe redline. You're better off just building the GSR internals.</TD></TR></TABLE>
yes you'll have to bend the oil squirters a bit, use the LS crank and LS rods. and increasing the stroke by 2mm, correction 1.8mm isn't gonna lower the safe redline by much. people always say stuff like this because of the LS' lower redline but little do they know that the LS' lower redline is due to many other things other than it's stroke. things such as poor valvetrain, poor flow, oil/water pumps, etc.
I'll be building my LS/Vtec soon as well and I will be using a Sleeved 84mm B18c block with LS internals.
speedking
May 25, 2008 08:31 PM
NAmodified
Sep 30, 2007 05:53 PM
hondahb12
11
Aug 2, 2004 04:44 AM
Teal95Coupe
Jul 12, 2003 02:19 AM
Project SSAP1
Jan 29, 2002 09:03 AM
