JDM eg fenders on 94 coupe
Old Feb 12, 2006 | 10:12 AM
1sickEJ's Avatar
Default JDM eg fenders on 94 coupe
it didnt come out to good it just seems like they didnt fit right any one knows whats going on or any ever put some JDM fenders on there own coupe i think i just might of gotton a bunk pair please help. also i was woundering which kinds of cluster will plug into my stock DX one i dont wanna mess wit wires but i need a tach is it possible
Old Feb 12, 2006 | 10:15 AM
92hatchling's Avatar
Default Re: JDM eg fenders on 94 coupe (91JDMRX)
not sure bout the fenders but any 92-95 cluster will work jus plug and play
Old Feb 12, 2006 | 11:10 AM
built562's Avatar
Default Re: JDM eg fenders on 94 coupe (92MiniMeHatch)
the fenders for a hatch and coupe are the same. they should bolt up perfectly.
are you experienced with body work at all? fenders need to be installed like so
unbolt your old ones, now take the new fender and loosly install all the bolts on the new fender, but do not tighten them. now adjust the fender to make sure all the lines look good, like the hood gap and door gap. then start to tighten the bolts slowly, be carefully because if you tighten a bolt it will pull the fender so it might mess with the lines to the body.
Old Feb 12, 2006 | 11:19 AM
dinko's Avatar
Default Re: JDM eg fenders on 94 coupe (built562)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by built562 &raquo;</TD></TR><TR><TD CLASS="quote">the fenders for a hatch and coupe are the same. they should bolt up perfectly.
unbolt your old ones, now take the new fender and loosly install all the bolts on the new fender, but do not tighten them. now adjust the fender to make sure all the lines look good, like the hood gap and door gap. then start to tighten the bolts slowly, be carefully because if you tighten a bolt it will pull the fender so it might mess with the lines to the body. </TD></TR></TABLE>
Old Feb 13, 2006 | 07:15 PM
1sickEJ's Avatar
yea i think it might just be a fuked up pair im gonna get new ones the taake it to a bodu shop
xXViperXx
27
Dec 21, 2008 11:17 AM
pastel
Honda Civic (2001 - 2005)
Mar 7, 2008 12:54 PM
drumbum87
Feb 22, 2007 05:33 PM
unknown0001
Nov 9, 2004 10:16 AM
Loveless
Jul 6, 2003 07:04 AM
