Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
Innovative EF/DA crossmembers 260 shipped out the door !
Old Feb 12, 2006 | 09:43 AM
project dc2's Avatar
Default Innovative EF/DA crossmembers 280 shipped out the door !
<U>Innovative Mounts Products</U>
<FONT COLOR="red"> Cross Members </FONT>
Civic CRX Front Crossmember $260 Shipped
DA integra front crossmember 275 Shipped
Civic CRX Front Crossmember HIMOUNT $260 shipped
ALSO CHECK OUT THEIR MOUNTS !!!!
<FONT COLOR="red">REVIEW </FONT> https://honda-tech.com/zerothread?id=1556058
Finish: Black Wrinkle Powdercoat Inserts: Red - 60A Shore Hardness Standard, Upgrade to Race or Track for $10 Extra.
Description: Designed Perfect Fitment! Unlike other kits, no notching or trimming of the hood is required. Positions the motor with no axle bind. When installed, maximum front clearance is available for large headers or a turbo. Unique no-tear vibration minimizing.bushings. <U>CAD/CAM Designed</U>. Stress Analyized. Lifetime warranty. More Info Visit http://www.innovativemounts.com
88-91 Civic and CRX Conversion Mount Kit for B Series Engines with Cable Transmission $175shipped
88-91 Civic and CRX Conversion Mount Kit for B Series Engines with Hydraulic Transmission $350shipped
92-95 Civic Replacement Mount Kit for B and D Series Engines with Hydraulic Transmission and 2 Bolt Post Mount Setup $300 shipped
92-95 Civic Replacement Mount Kit for B and D Series with Hydraulic Transmission and 3 Bolt Post Mount Setup $300shipped
92-95 Civic A/T to M/T Conversion Mount for B and D Series Engines with Hydraulic Transmission $89.95shipped
96-00 Civic Drivers Side Replacement Mount for B and D Series Engines $119.95shipped
96-00 Civic Replacement Mount Kit for B and D Series Engines with Hydraulic Transmission $300shipped
96-00 Civic Conversion Mount Kit for H and F Series Engines $300shipped
90-91 Integra Replacement Mount Kit for B Series with Cable Transmission $300 shipped
90-93 Integra Replacement Front Mount for B Series with Cable Transmission(NEW) $115shipped
92-93 Integra RS/LS Replacement Mount Kit for B Series with Cable Transmission $300shipped
92-93 Integra GSR Replacement Mount Kit for B Series with Cable Transmission $300shipped
90-91 Integra Replacement Mount Kit for B Series with Hydraulic Transmission $350shipped
92-93 Integra RS/LS Replacement Mount Kit for B Series with Hydraulic Transmission $350shipped
92-93 Integra GSR Replacement Mount Kit for B Series with Hydraulic Transmission $350shipped
94-01 Integra Replacement Mount Kit for B and D Series with Hydraulic Transmission $300shipped
94-01 Integra A/T to M/T Conversion Mount for B and D Series Engines with Hydraulic Transmission (NEW) $115shipped
02-06 RSX Replacement Mount Kit for Hydraulic Transmission (NEW)
$290shipped
92-96 Prelude Replacement Mount Kit for H and F Series (NEW)
$280.00 shipped
B/D Series Cable to Hydraulic Actuator (NEW) $180shipped
Crossmember Bushing and Caster Adjustment Set (NEW) $50 shipped
<U><FONT COLOR="blue">NEW INNOVATIVE BILLET SERIES !!!</FONT></U>
Item #: B10010
Cost: $175.99 SHIPPED - Driverside cage and mount
Finish: Unfinished Aluminum or Black Anodized.
Inserts: Red - 60A Shore Hardness Standard, Upgrade to Race or Track for $5 Extra.
Description: Available in Innovative's signature look of black finish or unfinished aluminum. <U>Billet Replacement </U>mount for 1996-2000 Honda Civic. Designed to fit all B and D series motors. An alternative to the mediocre oil filled factory mount. Urethane stiffness from soft for the street to solid for the track is available. CNC Machined from 6061 Aluminum. Unique no-tear vibration minimizing bushings. CAD/CAM Designed. Stress Analyized. Lifetime warranty. All hardware is included.
Item #: B19150
Cost: $249.99 SHIPPED
Description: Available in Innovative's signature look of black finish or unfinished aluminum. Billet Replacement mount for 1988-1991 Honda Civic or CRX. Designed to fit all B-Series motors (B16, B17, B18, B20) with cable transmission. Unlike other kits, no notching or trimming of the hood is required and even clears B20 engines. Positions the motor with no axle bind. When installed, maximum front clearance is available for large headers or a turbo. CNC Machined from 6061 Aluminum. Unique no-tear vibration minimizing.bushings. CAD/CAM Designed. Stress Analyized. Lifetime warranty.
PM me or email me if interested. SPoolindevelopment@gmail.com
paypal verified 500+ sales - trusted HT seller-
Modified by project dc2 at 11:37 AM 5/14/2006
Modified by project dc2 at 11:38 AM 5/14/2006
Old Feb 15, 2006 | 08:04 PM
sph33r's Avatar
Default Re: Innovative EF/DA crossmembers 280 shipped out the door ! (project dc2)
Got any pics of this mounted on a DA yet?
Old Feb 15, 2006 | 08:56 PM
Default Re: Innovative EF/DA crossmembers 280 shipped out the door ! (sph33r)
i will have the production models to put up . i have the prototype thats slightly diffrent in construction.
Old Feb 16, 2006 | 08:10 AM
ttt
Old Feb 16, 2006 | 02:25 PM
tony.yayo's Avatar
bump
Old Feb 17, 2006 | 01:57 AM
riceball777's Avatar
will this maintain the front motor mount ??
Old Feb 17, 2006 | 02:00 AM
Default Re: Innovative EF/DA crossmembers 280 shipped out the door ! (riceball777)
yes it will. i have a special for the DA motor moutn replacements if you wanna remove it
65$ for the front moutn replacement alone
and for the other 3 mounts. sides and rear are 285$ shipped steel welded with lifetime warranty.
Old Feb 17, 2006 | 08:49 AM
tttttttttt
Old Feb 17, 2006 | 10:27 AM
so you cant use the stock mouth with this crossmember. its only compatiable with your after matket front mount??
Old Feb 17, 2006 | 10:58 AM
you can use a stock front mount no problem. i was just informing you we make a complete mount setup and the front mount replacement can be purchased seperatley
Old Feb 18, 2006 | 06:40 AM
PM's replied keep em comin guys
Old Feb 19, 2006 | 10:28 AM
tttt
Old Feb 19, 2006 | 10:21 PM
91' LS-VTEC's Avatar
any pics of one installed? top veiw & bottom veiw.
Old Feb 20, 2006 | 07:31 AM
Default Re: Innovative EF/DA crossmembers 280 shipped out the door ! (91' LS-VTEC)
ill try to get some soon
Old Feb 21, 2006 | 01:16 AM
badboyr66's Avatar
Old Feb 21, 2006 | 08:13 AM
Default Re: Innovative EF/DA crossmembers 280 shipped out the door ! (badboyr66)
Old Feb 21, 2006 | 02:44 PM
tttttttttttt
Old Feb 22, 2006 | 06:15 AM
ttttttttt
Old Feb 23, 2006 | 07:53 AM
ttttttttt
Old Feb 24, 2006 | 07:26 PM
tttttt
Old Feb 25, 2006 | 11:14 AM
ttttttttttttt
Old Feb 26, 2006 | 09:25 PM
ttttttttt
Old Feb 28, 2006 | 10:50 AM
up up up
Old Mar 1, 2006 | 06:57 AM
tttttttttt
Old Mar 3, 2006 | 10:16 AM
ttttttttttttttt
