where can i get an uberdata bin for a modified gsr?
Old Feb 12, 2006 | 09:42 AM
the.hamburglar's Avatar
Default where can i get an uberdata bin for a modified gsr?
does anyone have a tuned gsr bin on here with i/h/e?
Old Feb 12, 2006 | 11:43 AM
96dc2's Avatar
Default Re: where can i get an uberdata bin for a modified gsr? (the.hamburglar)
Try http://pgmfi.org yet?
Old Feb 12, 2006 | 09:52 PM
Default Re: where can i get an uberdata bin for a modified gsr? (96dc2)
is there like a bin directory....cant find any on there.
Old Feb 12, 2006 | 11:29 PM
96dc2's Avatar
Here is one directory. Look in the forums, I think there are more in there as well.
Old Feb 15, 2006 | 08:32 AM
tried there and found nothing. anyone else have one?
Old Feb 15, 2006 | 10:52 AM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar &raquo;</TD></TR><TR><TD CLASS="quote">does anyone have a tuned gsr bin on here with i/h/e?</TD></TR></TABLE>
I'm going to assume that since you're no noob you understand that there is no such thing as a bin that will work as well as a map that is tuned for your engine/setup.
the pgmfi.org bin directory has the P72 base maps, go from there.
Old Feb 15, 2006 | 04:11 PM
Default Re: where can i get an uberdata bin for a modified gsr? (Relic1)
yes, im kinda of a newbie to this stuff but i know the bins will be close. everyone on here always says using someone elses bin is so bad but really its a good place to start. so im just asking. if i cant find on then ill start from scratch. there is nothing on the pgmfi webiste
Old Feb 15, 2006 | 04:31 PM
Relic1's Avatar
you're jumping into a pool that's significantly larger than you think. At least it is a crap load larger than I ever thought....
this may help. It's a base map based on the GSR with a little more fuel higher up, it should get you close.
http://forum.pgmfi.org/viewtopic.php?t=5495
Old Feb 15, 2006 | 06:18 PM
Default Re: (Relic1)
why would i want more fuel? i was thinking about taking some out...run it a little leaner...make it faster but safley...?
SpeedyDC5
Jul 18, 2007 02:42 PM
1badek
Nov 15, 2006 09:09 PM
eastbayrep
Oct 6, 2006 08:05 AM
AlwayzSpoolin
Sep 17, 2006 11:09 AM
deeweezy187
Mar 4, 2005 10:04 PM
