Timing Belt died
Old Feb 12, 2006 | 08:35 AM
whatan00b's Avatar
Default Timing Belt died
got a 92 integra ls just started it and it made wouldnt hold a idle got to 600 rpm and then it was done hopefully only being at that rpm didnt kill the valves or anything anybody had this happen before
Old Feb 12, 2006 | 09:22 AM
oilguzzler's Avatar
Default Re: Timing Belt died (whatan00b)
hate to say it man but if your timing belt did go at 600rpm, there wont be much left to work with. 99.8% sure that the vavles are done, open it up and take a peek.
Old Feb 12, 2006 | 09:24 AM
BlackLudeSi's Avatar
you should be ok my buddys Ls blew its T-belt at about 75 down the highway cuz of a cracked crank pully. When you get the news belt on just spin the crank slowly though a few rotations and make sure nothing hits.
but you never no
Old Feb 12, 2006 | 09:25 AM
runeminaEF9's Avatar
Default Re: Timing Belt died (oilguzzler)
if you think that's your problem, go have a leakdown or compression test ran on it to be sure. theres nothing worse than pulling your head just to find out its not the valves thats the problem.
Old Feb 12, 2006 | 09:28 AM
Default Re: Timing Belt died (runeminaEF9)
did the belt break? is that what died is, if it didn't break it just might be way off or your dizzy could be bad or not set.
Old Feb 12, 2006 | 09:49 AM
PLAGUED_DB7's Avatar
Default Re: Timing Belt died (BlackLudeSi)
my buddys T-belt broke and when we took off the valve cover it had scratches on it, and he needed a whole new valve train
Old Feb 13, 2006 | 07:40 AM
whatan00b's Avatar
Default Re: Timing Belt died (PLAGUED_DB7)
well yeah its broke its at the shop right now havent heard anything on it. Hopefully i got really lucky. it broke on a cold start thats whats wierd.
Old Feb 13, 2006 | 07:45 AM
daoshao's Avatar
hopefully you are the lucky few with no bent valves......yeah, you should really change it every 90,000 miles.......its actually not that difficult to do...
Old Feb 17, 2006 | 06:09 PM
whatan00b's Avatar
Well no bend valves WHOO HOOO thank god couldnt have afforded that
Cripton805
Jan 9, 2022 07:15 PM
woodin
Apr 8, 2008 09:26 AM
ampm
12
May 3, 2007 10:53 PM
AlexT
Sep 28, 2004 06:07 AM
PatEJ6
Apr 11, 2002 09:21 AM
