internals vs. turbo!!!!!
hey, i have got a 95 teg ls, and i wondering if i should change the intearnals if i turbo it up.would i have to build the engine up? and if i did turbo it, how much HP
95 non-vtec
ractice cold air intake
apex n1 full exhast
dc headers
dropzone suspension kit(2in)
95 non-vtec
apex n1 full exhast
dc headers
On stock internals you can run up to 10psi give or take. <U>The key is tunning</U> if it is tunned right you will not have any problems. It wouldnt hurt to sleeve it and do sme head work later on if you want more boost.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bryguy18 »</TD></TR><TR><TD CLASS="quote">hey, i have got a 95 teg ls, and i wondering if i should change the intearnals if i turbo it up.would i have to build the engine up? and if i did turbo it, how much HP
95 non-vtec
apex n1 full exhast
dc headers
do a compression test to make sure the piston rings and valves are all sealing good. If you get good results.. go for it. I was making 260whp and 210 ft lbs of tq on my stock b18b when I had it.. Yea tuning is the most important part of running any turbo set up.
95 non-vtec
apex n1 full exhast
dc headers
I hate everything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bryguy18 »</TD></TR><TR><TD CLASS="quote">so are the internals in the ls pretty dependable? </TD></TR></TABLE>
Well like stated aboive, you can run about 10psi safely. People use LS for boosting because of its low compression. But if you plan to run like 18psi on a stock motor, your asking for trouble.
yes, they are dependable because of there low compression...and i would consider a compression check, if your not going to build your motor. You should be okay, for 10psi...but u really cant measure in psi...it also matters about your tuning, and what size turbo you get...a big *** turbo at 10psi is different from a little greddy turbo at 10psi.i would build first, then turbo, but thats me
