no vtec
Old Feb 11, 2006 | 07:22 PM
686_ef's Avatar
Default no vtec
i just dropped a new motor in my ef so i have not wired up the vtec to the ecu yet. so i riged the vtec to a button for a day till i can wire up the vtec to the ecu.. but then it just didn't work so i took off the the solenoid to check it out, so i cleaned it and put it back on and still no vtec.. could it be the oil presure or the solenoid f&cked up or could it be something in the head..
ohh ya the motor is a b16a
Old Feb 11, 2006 | 07:32 PM
eda6's Avatar
Default Re: no vtec (686_ef)
why don't you wire it up right and see what happens.
I bet your ecu is throwing code 21 or 22 and that's why vtec isn't working.
Old Feb 11, 2006 | 07:52 PM
686_ef's Avatar
Default Re: no vtec (eda6)
ya i know that but you can hear the solenoid when it clicks on but no vtec at all it s not the wiring its some thing else
thanks anyway
Old Feb 11, 2006 | 08:45 PM
jccrxtuner916's Avatar
does ur speedometer work???? umm.. any other codes on ur ecu....
for vtec to work the:
1 speedometer has to work
2 no codes on ecu
3 wired correctly
sounds liek i knwo what im talkign about huh.. well my vtec is not working so i've been looking into what it could be and i came across a few interesting things...
Old Feb 11, 2006 | 08:48 PM
sohctodohc's Avatar
Default Re: (jccrxtuner916)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jccrxtuner916 &raquo;</TD></TR><TR><TD CLASS="quote">does ur speedometer work???? umm.. any other codes on ur ecu....
2 no codes on ecu
3 wired correctly
4. oil pressure!!
sounds liek i knwo what im talkign about huh.. well my vtec is not working so i've been looking into what it could be and i came across a few interesting things...</TD></TR></TABLE>
Old Feb 11, 2006 | 08:52 PM
crxnj's Avatar
Default Re: (sohctodohc)
That stuff doesnt matter..He is running vtec with a button..So it sounds like you're low on oil..You better run a 30amp relay with the button or you will blow out the solenoid,,
Old Feb 11, 2006 | 09:04 PM
686_ef's Avatar
Default Re: (Mr.speaker)
i was runnig the vtec with direct current for now till i get the ****** vss right on my gsr cluster thats a bicth man.. it has oil, today i changed the oil pan on the motor and i put new oil in it.
i think its either
1. solenoid is messed up
2.theres something wrong in the head
3. or low oil pressure which means (new oil pump)
Old Feb 12, 2006 | 11:03 AM
686_ef's Avatar
Default Re: (686_ef)
some more info would be nice
Old Feb 12, 2006 | 08:06 PM
686_ef's Avatar
bump this biaaaaaaaaacth...!
Old Feb 13, 2006 | 12:18 AM
sohctodohc's Avatar
my brother hit a ditch once in his accord his vtec quit working and a couple days lata it worked again. maybe your honda will fix itself
Old Feb 13, 2006 | 07:17 PM
686_ef's Avatar
i hope man cause this is just driving me nuts, it has stoped the hole project.
Old Feb 13, 2006 | 07:22 PM
1RMDave's Avatar
just hook it up right please! you won't see nearly the performance gain like this because your ecu won't be using the vtec fuel/ignition maps. it'll just toss on a different cam lobe and not compensate for it.
Old Feb 13, 2006 | 08:31 PM
jdeemseerx's Avatar
if the speedo doesnt work you wont have vtec...u just answered your own question "i was runnig the vtec with direct current for now till i get the ****** vss right on my gsr cluster thats a bicth man.. it has oil, today i changed the oil pan on the motor and i put new oil in it"
swizz977
10
May 25, 2011 08:15 PM
bigsubs
Jun 15, 2007 08:42 PM
vtecn8ive
Apr 20, 2006 09:14 PM
MugeNinja
Dec 29, 2005 09:50 AM
b19coupe
Sep 3, 2003 07:02 PM
