Car Turns off when i step on breaks
Old Feb 11, 2006 | 06:19 PM
QuickRexSi21's Avatar
Default Car Turns off when i step on breaks
Im trying to get my friends hatch running again, he has a B16 in a EF9, Type R pistons, and type R manifold, whoever put that engine in is a ******* idiot though, they left a lot of hoses just sitting there, the knock sensor isnt plugged in, and the fuel rail was leaking gas, well today we fixed the fuel rail problem. and we got the car started, but when i tapped on the breaks it turned off, i noticed that the batter wasnt grounded to the frame of the car, could this be the problem??? or can it be a short somewhere? or maybe the battery is out of juice? because we did have to jump start it, and when it turned off the battery was done for it!....any advice?? thanks
Old Feb 11, 2006 | 06:28 PM
saikouEF8's Avatar
Default Re: Car Turns off when i step on breaks (QuickRexSi21)
car is grounding out... check all ground wires.
InEK's Avatar
is it only happening when you hit the brake? if it was the battery ...it wouldnt make a diff. if you hit the brake or not..when you turn on the car put all accesories on and see if it stays on...if it doesnt..prob battery...try cleaning out the ground too
Old Feb 11, 2006 | 07:02 PM
Default Re: Car Turns off when i step on breaks (saikouEF8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saikouEF8 &raquo;</TD></TR><TR><TD CLASS="quote">car is grounding out... check all ground wires.</TD></TR></TABLE>
alright ill check that out, and see if thats the prob
Old Feb 11, 2006 | 07:03 PM
Default Re: (BlackEF8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackEF8 &raquo;</TD></TR><TR><TD CLASS="quote">is it only happening when you hit the brake? if it was the battery ...it wouldnt make a diff. if you hit the brake or not..when you turn on the car put all accesories on and see if it stays on...if it doesnt..prob battery...try cleaning out the ground too</TD></TR></TABLE>
the car will stay on, after we jump start it, and take off the cables, but after i tap the break, or turn on lights, it will just shut off and wont turn back on unless we jump start it....
Old Feb 11, 2006 | 07:04 PM
trrbl1bmx's Avatar
dude... it's BRAKE not break
Old Feb 11, 2006 | 07:11 PM
mar778c's Avatar
Community Builder
Community Influencer
check to see if the alternator is charging. It may be the battery is beyond a recharge.
Old Feb 11, 2006 | 07:48 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (goCRXgo)
kind of a weird idea, but ill throw it out there..
the brake switch to turn on your brake lights on the brake pedal might be broken. it could be grounding out the rest of the system. i believe the switch is plastic and has been known to break.. it might also explain why just turning on your lights kills it too, cause i think the power is routed through the same line. i guess it doesnt explain why your car is completly shutting off.. but its an idea.
Old Feb 11, 2006 | 08:03 PM
xaine's Avatar
Default Re: (sanimalp)
it is the alternator
the battery
or no good ground
or a combonation of the above
Old Feb 11, 2006 | 10:04 PM
i hate rice's Avatar
Default Re: (xaine)
i had the same problem for a while in my car, ecp mine was with the shift linkage when i put it in gear it would turn off. make sure the ground goes from the bat. to the frame and the tranny. cause when it happened to me it had me stumped for a while
Old Feb 11, 2006 | 10:10 PM
NAS_OCSICNARF
Guest
Posts: n/a
Default Re: (ilovemyef9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilovemyef9 &raquo;</TD></TR><TR><TD CLASS="quote">dude... it's BRAKE not break</TD></TR></TABLE>
Old Feb 11, 2006 | 11:59 PM
oh my bad, didnt know this was a spelling bee, did you know what i was trying to say?? im asking for help not a spell check....why do people go on honda tech just to rant on minor things...some dudes are worse than bitches...
Old Feb 12, 2006 | 12:04 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goCRXgo &raquo;</TD></TR><TR><TD CLASS="quote">It seems no one on HT is ever familiar with CCA. It sounds to me like A.It's a grounding Issue, and B.Your battery is bad, it cant hold the proper amount of CCA (coldcrankingamps) to start the car.</TD></TR></TABLE>
ill switch out the battery, and make sure all the grounds are look good
Old Feb 12, 2006 | 12:05 AM
Default Re: (gone in 13 Seconds)
yeah, i think that might be the problem, well not the shift linkage, but the ground on the battery cable.
Old Feb 12, 2006 | 03:00 AM
SwissChEz82's Avatar
Default Re: (QuickRexSi21)
The smartass answer would be take the car out of gear before you completely stop the car. But seriously it sounds like a grounding problem to me.
Old Feb 12, 2006 | 02:48 PM
InEK's Avatar
I think everyone who owns a car knows what cca's are..so lets seriously help him out and not bee ********.. Either way bro ..your gonna have to try and recharge that battery or buy a new one...if you have to jump it so frequently. Make sure you have a good clean ground....check your alternator with a Full Charged battery. hope this helps
Old Feb 12, 2006 | 03:04 PM
da9wonder's Avatar
damn the guy who did the swap for u guys sucks *****
Old Feb 12, 2006 | 07:25 PM
Take your own advice about not bein an *******.....
and it appears he didn't know about CCA.
And it's very possible thats the problem. It is more then possible for a Battery to hold a charge and not have the proper CCA. I just threw out a battery 2 months ago. Held the proper 12 Volts, had me stumped, til I got a voltmeter that read CCA and found it was far below the required amount. New battery, problem gone.
If he's done the home test of removing the battery cables will it's running to see if the alternator is working, and if it is working, I'd be willing to bet its CCA, or ground, like I said</TD></TR></TABLE>
i know what cca is, i was just asking a simple question and wanted to know if anyone has had this problem before....thanks for the help guys.
Old Feb 12, 2006 | 07:26 PM
Default Re: Car Turns off when i step on breaks (crxwonder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxwonder &raquo;</TD></TR><TR><TD CLASS="quote">damn the guy who did the swap for u guys sucks ***** </TD></TR></TABLE>
thats JPR for you!!, i did my own swap on my car, my friend took his in for some reason???? oh well....im just trying to help him out.
Old Feb 19, 2006 | 09:58 PM
Old Feb 19, 2006 | 10:40 PM
Bob_760's Avatar
This is exactly what happened when i tried to run my crx with NO battery for a minute, and twice when other cars of mine have had flat dead batterys. The brake lights seem to draw alot very suddenly, the alternator cant take it, so it kills the ignition.
Replace/Charge batt you should be fine
Old Feb 20, 2006 | 03:50 PM
Default Re: Car Turns off when i step on breaks (Bob_760)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob_760 &raquo;</TD></TR><TR><TD CLASS="quote">This is exactly what happened when i tried to run my crx with NO battery for a minute, and twice when other cars of mine have had flat dead batterys. The brake lights seem to draw alot very suddenly, the alternator cant take it, so it kills the ignition.
Replace/Charge batt you should be fine </TD></TR></TABLE>
thanks man....
Old Feb 20, 2006 | 04:18 PM
jdmEFricer's Avatar
does it have an alarm or remote starter?? cause it might have a problem there?? i don't know.. i'm no mechanic.. just from persomal experiences
jake
Old Feb 23, 2006 | 08:56 PM
Default Re: (jdmEFricer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmEFricer &raquo;</TD></TR><TR><TD CLASS="quote">does it have an alarm or remote starter?? cause it might have a problem there?? i don't know.. i'm no mechanic.. just from persomal experiences
jake</TD></TR></TABLE>
yeah it had an alarm. we took it out. i havent worked on that car, it was my birthday last weekend and i wasnt about to work on cars on my bday, so ill check it out this weekend.
superhatchbackbros
26
Apr 26, 2007 04:44 PM
x91crxsix
Dec 6, 2006 09:40 AM
JDMdamian95
30
May 30, 2006 10:19 AM
srswarts3
Aug 6, 2005 03:47 PM
TurboMiata
Apr 6, 2003 10:45 AM
