gauge ?
Old Feb 11, 2006 | 05:52 PM
dasistheone's Avatar
Default gauge ?
My lights on my gauge wont light up when I turn my headlights... I just purchase a ex gauge cluster and i am puttin in my cx..everything else works fine
i wan know which bulb controls the illumination..
I have a 92-95
Old Feb 11, 2006 | 06:03 PM
Default Re: gauge ? (dasistheone)
bumpin i really need an answer
Old Feb 11, 2006 | 06:20 PM
92hatchling's Avatar
thats a commem problem with 92-95 civics not sure what causes it but mine does it just smack the top of the dash above the cluster it may come on might have to smack a time or to but if you figure out what causes it let me know
Old Feb 11, 2006 | 06:29 PM
Default Re: gauge ? (92MiniMeHatch)
bump thanks ne more suggestions
Old Feb 11, 2006 | 06:32 PM
WARCOVENANT's Avatar
on a 99/00 cluster there is one bulb that controls most of the illumination.. its located in the center on the back.. i dont know much about the 92-95. worst case scenario.. take it to the parts counter of your dealer and have them take a look at it. im sure the bulb only costs a few dollars and they will know where its located and how to change it.
Old Feb 11, 2006 | 06:40 PM
Default Re: gauge ? (twelvesorbetter)
bump n e more ideas... what bubs before i go to the dealer
I am snowed in
Old Feb 11, 2006 | 07:29 PM
HOWFAKE's Avatar
Same thing happen to me on my 99 civic dude...all my bulbs were burnt out i changed em but nothin...and now my mph gauge dosent work either...but check evry fuse,light relay,harness..
Old Feb 11, 2006 | 07:33 PM
isumase's Avatar
Default Re: (HOWFAKE)
check out your dimmer switch, had this problem and changed that and it worked, search as well cause this is a common problem in eg's. change dimmer switch FTW!!!
Old Feb 11, 2006 | 07:40 PM
Default Re: (isumase)
I am gonna plug my old one back in and see if works
Old Feb 12, 2006 | 10:18 AM
Default Re: (dasistheone)
The old one works fine... So i feel its the cluster. I am gonna change the cluster blubs from my old one and put it in the new one and see what happens
Old Feb 12, 2006 | 11:55 AM
isumase's Avatar
so when you plugged in the old one the lights did or didnt come on? cause if they came on it means you prolly got a bad switch. id go ahead and replace it cause theyre not too expensive and no other worries.
Old Feb 13, 2006 | 10:38 AM
I took the bubls from the old cluster(which is the exactlly same as the blubs that were in the ex cluster) And put it in the ex cluster it still did not work.. Then i took those blubs that i just put in the in the ex cluster and put it back into the old cx cluster and it worked.. Soi now kno its the cluster is there any thing i can do to fix this... Everything works fine except that...
Old Feb 13, 2006 | 04:10 PM
talked to my friend today - whos car the cluster came from, and he says it works 100% and did the entire time he had it. he even said that hed be glad to take it back and use it... so something doesnt add up. if you dont want it, send it back. we have unfinished business to take care of as it is.
EFnCRX
Dec 11, 2013 10:25 AM
speddiek
Oct 10, 2008 01:01 PM
Tmaeroxtreme3161
11
Oct 20, 2006 05:34 PM
xbladr
Mar 21, 2005 09:26 PM
josups
Jan 30, 2003 09:44 PM
