b20 vtec build will teg type r pistons work?
I really am having some troubles, I need to know if integra type r pistons will work in my b20 block. I have gotten both yesses and no's s please only answer if you really know, thanks
whered you order those pistons from? im considering a b20 build only thing holding me back is i dont know what pistons to use or where i should get them from
good luck though that'l be a fun one when shes done!
These NPR itr pistons will fit. https://honda-tech.com/zerothread?id=1481588 Compression is not what cracks b20 blocks detonation does, if you run racing gas you can run 11.5 in a b20. Set your cr at 10.5 and it will be fine on 91. Dan
Modified by Dan Ruddock at 5:40 PM 3/7/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ruben19 »</TD></TR><TR><TD CLASS="quote">watch those b20 sleeve crack. with that compression
if they are stock.
b20 sleeves wont hold for too long..</TD></TR></TABLE>
not true, they can hold decent power, they are just very sensitive to detonation. if tuned well u will be fine. i put 11k miles on a b20z bone stock block/ turbo. went 239 whp, 231 trq. sold the shortblock still runs to this day in a b20/vtec all motor
if they are stock.
the pistons in the link posted above are apparently very good pistons. i havent used them but i saw a thread on here that prostreetimport put them in a b20/vtec that made 244whp untuned. and a b20/vtec will withstand 11.5:1 compression all day just watch out for detonation.
