Suspension & Brakes Theory, alignment, spring rates....
Sway Bar Compatibility
Old Feb 11, 2006 | 01:26 PM
JDMmaster's Avatar
Default Sway Bar Compatibility
A couple questions:
1) Will a 2001 Integra GSR rear sway bar and end links fit on a 2000 civic coupe, or is a combination of GSR sway and civic end links required, or not at all?
2) What is the size diameter, and if it does fit, should a re-enforcement plate be used?
Thanks!
Old Feb 11, 2006 | 02:05 PM
Voyage34's Avatar
Default Re: Sway Bar Compatibility (JDMmaster)
I have a gsr sway bar on my 96 coupe, with the endlinks that came with it (junkyard raid). Yes it fits, I had to mess with how some stuff lines up with minor drilling, and use a few washers for it to be spaced functionally.
The bar itself is a 14mm diameter, no need for a brace with that size. 19mm is usually the cutoff for reinforcement.
Old Feb 13, 2006 | 03:29 PM
JDMmaster's Avatar
Default Re: Sway Bar Compatibility (Voyage34)
Could you elaborate on what you had to drill and what needed spacers please.
Old Feb 13, 2006 | 04:19 PM
Voyage34's Avatar
the stock endlinks didnt line up with the holes in the lca's. IIRC they were 1 1/4" or so inward, so i drilled new holes on those.
The spacing was for the bracket that mounted to the subframe, the frame side had an S-shape to it so i used wide washers to bring the sides to an even plane and to maximise the surface area on the frame as a makeshift beaks kit. PM me your email and I'll send you pictures of what i have.
lxdriver
Suspension & Brakes
Dec 8, 2010 05:13 AM
ef8-dc2619
Suspension & Brakes
May 9, 2007 01:08 PM
EG6LS
Suspension & Brakes
Dec 29, 2005 01:06 AM
Fez
Jul 22, 2002 01:05 PM
DreamSpeed
14
Oct 25, 2001 09:57 AM
