Is there a problem with having a 17" & a 15" wheel on the front of the car?
Old Feb 11, 2006 | 12:16 PM
Integra_RS's Avatar
Default Is there a problem with having a 17" & a 15" wheel on the front of the car?
j/w... had a blow out the other night and im on 17's, & decided to throw a 15" LS mesh to hold me over for a few more days. I plan on going cruising around tonight... is it bad to have one 17" wheel on one front axle and having a 15" on the other front axle? I have heard there can be problems, but what can cause the problems? LMK...
Old Feb 11, 2006 | 12:21 PM
switchd9497's Avatar
im running the same way right now.
had a blow out about a week ago. now ive got 17s on all three except my front passenger side. there ive got a 15 fat 5...
im not sure if its bad or not, but i guess we will both get help out of this post...
Old Feb 11, 2006 | 12:23 PM
TunerN00b's Avatar
Default Re: Is there a problem with having a 17" & a 15" wheel on the front of the car? (Integra_RS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra_RS &raquo;</TD></TR><TR><TD CLASS="quote">j/w... had a blow out the other night and im on 17's, & decided to throw a 15" LS mesh to hold me over for a few more days. I plan on going cruising around tonight... is it bad to have one 17" wheel on one front axle and having a 15" on the other front axle? I have heard there can be problems, but what can cause the problems? LMK...</TD></TR></TABLE>
The wheel size doesn't mean anything. Its the tire size.
If both the tires have the exact same external diameter, then you should be fine. Otherwise, I suppose it could cause issue swith the transaxle. You're supposed to put the temp spare on the back, and move a back tire to the front, so it would probably be best if you did that now, but with the LS wheel instead of the spare.
Old Feb 11, 2006 | 12:26 PM
numbnuts22715's Avatar
Default Re: Is there a problem with having a 17" & a 15" wheel on the front of the car? (TunerN00b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">The wheel size doesn't mean anything. Its the tire size.
If both the tires have the exact same external diameter, then you should be fine. Otherwise, I suppose it could cause issue swith the transaxle. You're supposed to put the temp spare on the back, and move a back tire to the front, so it would probably be best if you did that now, but with the LS wheel instead of the spare.</TD></TR></TABLE>
I agree with him. Id put the smaller tire on the back,
Old Feb 11, 2006 | 02:23 PM
Integra_RS's Avatar
Bump for opinions.
Old Feb 11, 2006 | 02:55 PM
batmang yO!
Guest
Posts: n/a
Default Re: (Integra_RS)
taking a good tire from the back putting it in the font, then putting the spare in the back is the right thing to do, but I wouldn't really worry too much unless you have lsd.
Old Feb 11, 2006 | 02:56 PM
nsxtasy's Avatar
H-T Order of Merit
Same opinion.
It depends on the diameter of the tire, not of the wheel.
The unmatched pair should go on the rear of the car.
It's okay as a temporary measure; it's better than using the donut spare. But I wouldn't recommend it for an extended period of time, since the handling can be unpredictable when using unmatched tires.
Old Feb 11, 2006 | 03:04 PM
Dogginator's Avatar
Daisy... Daisy...
It could cause stability problems during hard braking (panic stop) if one tire has much more grip than the other. I agree with the others, put the mismatched tire on the back.
cr8zy Somalian
Jul 8, 2007 07:55 PM
futurefastguy
Mar 28, 2005 06:47 PM
SIcivicHATCH
11
Jan 21, 2005 12:34 AM
MrMayhem
May 20, 2004 12:54 PM
CunninLynguist
May 7, 2003 11:54 AM
