splitting si tranny case.... how do i do it? asap
Old Feb 11, 2006 | 09:59 AM
fbw2003's Avatar
Default splitting si tranny case.... how do i do it? asap
trying to split the casing on an 89 d16a6 cant get it to come all the way apart, we got a gap btwn the belhousing and and the actual gearbox but it wont come all the way apart. any help will be appreciated.
Old Feb 11, 2006 | 10:11 AM
jlicrx's Avatar
Default Re: splitting si tranny case.... how do i do it? asap (fbw2003)
on the back of the case is a 32mm plug with a square hole in it that a 3/8" ratchet will fit in - remove the plug - look down in the hole and you will see a snap ring that fits in a groove in the countershaft bearing and another groove in the case - spread that ring open as far as you can to get it out of the bearing groove and pull up back half of case
Old Feb 11, 2006 | 10:32 AM
fbw2003's Avatar
Default Re: splitting si tranny case.... how do i do it? asap (jlicrx)
thanks worked like a charm.
skata89
May 11, 2007 02:49 PM
Fastwhip
Oct 20, 2006 03:06 PM
crexer
Oct 4, 2004 06:00 PM
Traction
Sep 26, 2004 06:13 PM
nsxmatt
Jun 4, 2003 07:26 PM
