Sound while braking
Old Feb 11, 2006 | 06:37 AM
Integra Integra's Avatar
Default Axle? Whats the part #?
I was able to get it on a jack today and saw the boot above the lower control arm on the passenger side was leaking fluid, I don't see a tear it appears to be coming from the side were the clip is. Its not the boot that meets the wheel (CV) its the once smaller above the lower control arm. Heres a pic:
Were can I get the part and is it to hard to replace?
Modified by Integra Integra at 8:59 PM 2/17/2006
Old Feb 11, 2006 | 06:42 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Sound while braking (Integra Integra)
Pull the offending wheel, caliper, and rotor and check for rubbing. Is the rotor corroded or pitted? Does the rotor have runout?
Old Feb 11, 2006 | 06:50 AM
Default Re: Sound while braking (Dogginator)
The rotor has a bead of rust around the outside edge were the caliper does not meet, the calpier has a bit of surface rust on it.. I will put it to see whats goin on
Old Feb 11, 2006 | 08:40 AM
Old Feb 11, 2006 | 08:52 AM
Bump anyone know what boot that is?
Old Feb 11, 2006 | 09:27 AM
Arsenal's Avatar
Its the tie rod for the steering rack. Actually the inner one. Little hard to replace, can get them from Autozone.
Old Feb 11, 2006 | 10:17 AM
Default Re: Sound while braking (Arsenal)
I am gonna try refilling it and tighening the boot up because theres no tears just seems loose, what grease do I refill with?
Old Feb 17, 2006 | 07:59 PM
EDIT: Is it the Tie Rod End Inner? I found it on ProStreetOnline OEM for $42.00 seems OK
Old Feb 17, 2006 | 08:07 PM
RTI's Avatar
RTI
that definitely looks like the inner joint for the steering.
Old Feb 18, 2006 | 04:29 AM
Default Re: Sound while braking (RTI)
Have a link or part # to where I can get it online?
Old Feb 18, 2006 | 05:38 AM
Dogginator's Avatar
Daisy... Daisy...
As always:
http://www.acuraparts247.com
Old Feb 18, 2006 | 05:47 AM
Thanks you wouldn't happen to have a part # now would yOU?
Old Feb 18, 2006 | 05:49 AM
Dogginator's Avatar
Daisy... Daisy...
You can look it up quite easily. That site provides diagrams and part numbers. You know the specifics of your car. I do not.
Old Feb 18, 2006 | 05:54 AM
Oh ok thank you, it is not too dangerous to drive it like that for a while right?
drtysoufchevy
Suspension & Brakes
54
Jan 28, 2019 07:19 PM
kenzo42
Sep 2, 2013 10:17 PM
93jdmb16aII
Suspension & Brakes
Apr 19, 2013 03:37 AM
rick_rabies
Oct 28, 2010 04:17 PM
drtysoufchevy
17
Sep 16, 2010 11:13 AM
