want to swap 95 ls motor in my 91 si?
Old Feb 10, 2006 | 08:35 PM
JDMfrontedLS's Avatar
Default want to swap 95 ls motor in my 91 si?
What will i need to do? The motor is complete obd1 and i know i need to get motor mounts. which axles can i use? and which ecu should i use? also which shift linkage? if im missing any other info please let me know.
Old Feb 10, 2006 | 09:44 PM
91whiteZCrex's Avatar
Default Re: want to swap 95 ls motor in my 91 si? (JDMfrontedLS)
if you have an hf you have to get si or dx hubs, then you can use 90-93 teg axles
hasport makes the linkage for 150 and innovative mounts are 180 i belive. then you will need to get an obd1 conversion harness. there are some more random things but i cant think of them
Old Feb 12, 2006 | 02:03 AM
coo thanks man. what ecu will i need to run or can i use the ls ecu?
Old Feb 12, 2006 | 05:23 AM
Mr Synister's Avatar
Default Re: want to swap 95 ls motor in my 91 si? (91whiteZCrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91whiteZCrex &raquo;</TD></TR><TR><TD CLASS="quote">if you have an hf you have to get si or dx hubs, then you can use 90-93 teg axles
hasport makes the linkage for 150 and innovative mounts are 180 i belive. then you will need to get an obd1 conversion harness. there are some more random things but i cant think of them</TD></TR></TABLE>
I agree but I say just get hasport mounts. As for ecu you have to use a P75. If you want more info just go here
http://faq.ef-honda.com/index....ng=en
Old Feb 12, 2006 | 07:06 PM
Default Re: want to swap 95 ls motor in my 91 si? (Mr Synister)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Synister &raquo;</TD></TR><TR><TD CLASS="quote">
http://faq.ef-honda.com/index....ng=en</TD></TR></TABLE>
yaya hasport...innovative same thing, hasports have been around longer, and look cooler but innovatives dont vibrate
evosix
14
May 22, 2010 08:50 PM
kyle1jzsupra
Aug 29, 2008 02:57 PM
AJxr
Feb 24, 2006 12:28 AM
nicklk
Feb 26, 2005 10:34 PM
GDM Z28
Feb 13, 2003 02:18 PM
