Oil leaking out if drain bolt??help
looked under my car and saw a little oil spot. It is coming from the oil drain bolt. leaking very slowly. only a few drips a day. what could cause this? how can i fix it?
edit:it is tightened all the way, and there looks to be no cracks.
Modified by D 2da A9 at 11:16 PM 2/10/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackDC2_05 »</TD></TR><TR><TD CLASS="quote">new washer should fix it.</TD></TR></TABLE>
its like 93 cents or something or was it 63 cents.... i duno all i remember is that its less then a dollar at acura
alright cool, dose anybody know the washer size i dont want to have to bring the bolt i just changed my oil 100 miles ago i dont want it all to drain out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joso2005a »</TD></TR><TR><TD CLASS="quote">"under your can"??? is it still leaking? you might just need a new washer or the bolt is not tighted to specs??? good luck</TD></TR></TABLE>
lol car*
lol car*
5th gen ludette : You said your oil pan threads where stripped? Mine are also stripped and I had an oversize bolt put in. It still drips some out everyday but not enough to worry about. I was told I could goto Canadian Tire and get this rubber plug that can go in and as you tighten it up it expands out to fill the hole? What did you do? Anyone else have input I'd like to hear it also.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by da_33 »</TD></TR><TR><TD CLASS="quote">5th gen ludette : You said your oil pan threads where stripped? Mine are also stripped and I had an oversize bolt put in. It still drips some out everyday but not enough to worry about. I was told I could goto Canadian Tire and get this rubber plug that can go in and as you tighten it up it expands out to fill the hole? What did you do? Anyone else have input I'd like to hear it also.</TD></TR></TABLE>
well for the time being, yea I put an oversized plug..but like you said, it would still leak. I ended up replacing the pan all together.
93(Civic)EG6
Nov 3, 2006 02:25 PM
