ST sway bar.....
I just install the st front and rear sway bars set....when i mount the L-bracket the lca bolt only have a few threads...is that normal? and what size bolt should i get to fix it?
How can i use my tie bar with the st sway bar??
the bolt should be fine as long as it's torqued down to specs. if you feel uncomfortable with the existing bolt you can do one of 2 things:
1. replace your lower control arm for an oem one that has the holes for the sway bar (thats what i did).
2. go to your local hardware or parts shop and find a replacement bolt w/ same size threading, but just a little longer.
in my opinion st should have supplied you with a replacement bolt. you can also give them a call and see what they suggest. hope everything works out. good luck
96Formula6spd
Jun 9, 2011 05:13 PM
byronl
Jul 18, 2006 05:54 PM
