Resistor Box
Old Feb 10, 2006 | 05:16 PM
Rukusmasta2's Avatar
Default Resistor Box
i got 89dx obd0 running a obd1 p28 conversion i was told i should run a resistor box because it will fry my injectors let me know cuz as of now i got resistor box wired up but havent started car yet.
Old Feb 10, 2006 | 05:20 PM
Deetz's Avatar
Crazy Honda Guy
The deal is:
-if runnning stock Si injectors (obd0), keep the resistor box
-if running the new obdI or II injectors, the injector box muxt be removed, and some minor wiring is needed to power the injectors correctly.
Old Feb 10, 2006 | 05:45 PM
si0385.'s Avatar
Default Re: (Deetz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deetz &raquo;</TD></TR><TR><TD CLASS="quote">The deal is:
-if running the new obdI or II injectors, the injector box muxt be removed, and some minor wiring is needed to power the injectors correctly.</TD></TR></TABLE>
in a nut shell
what injectors are you running?
jlicrx's Avatar
Default Re: (jaydeum4lyfe)
http://www.hondata.com/techlowohminjectors.html
Old Feb 11, 2006 | 10:43 AM
Default Re: (jlicrx)
i got OBD2 gsr ones running OBD1 p28
Old Feb 11, 2006 | 01:50 PM
C_R_X-si's Avatar
Default Re: Resistor Box (Rukusmasta2)
All i can say is play it safe bro.
Old Feb 11, 2006 | 04:14 PM
Default Re: Resistor Box (C_R_X-si)
what are you seriously talking about
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C_R_X-si &raquo;</TD></TR><TR><TD CLASS="quote">All i can say is play it safe bro.</TD></TR></TABLE>
what does that have to do with anything post something informative.
Old Feb 11, 2006 | 04:18 PM
Mach69's Avatar
What a great post that was.
OBD2 GSR injectors, you should NOT have the resistor box there. Take it out and solder the 5 wires that were going to the box together. BTW, the gsr injectors flow 240cc, same as out d-series injectors.
Old Feb 11, 2006 | 04:28 PM
Default Re: Resistor Box (Mach69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 &raquo;</TD></TR><TR><TD CLASS="quote">What a great post that was.
OBD2 GSR injectors, you should NOT have the resistor box there. Take it out and solder the 5 wires that were going to the box together. BTW, the gsr injectors flow 240cc, same as out d-series injectors.</TD></TR></TABLE>
No Sir, What a great post THAT was. Thanx.
ej1serge
Mar 14, 2012 11:33 PM
deucedeuceEK
Oct 30, 2007 04:35 PM
MysteryWagon
Jun 17, 2005 04:16 AM
B18 CYA
Jun 24, 2004 06:44 PM
