My swap help z6 head
Old Feb 10, 2006 | 04:05 PM
Cashieboi's Avatar
Default My swap help z6 head
so im doing a minime swap in my hatc, i have the p28 ecu i have the timing belt, i still need the gaskets and wiring, but im not shure exactly what wiring it is that i need, and what i need off the solenoid and all that i need, i also dunno if my stock distributor will work with this head, because the z6 head doesnt have a distrubutor, someone please help and sumhow tell me what wiring,harnesses, etc i need to complete my swap? myabe a picture of sumthing? because knowing me i would get the wrong thing from a junk yard or not all of it... and yea i would be mad, thanks would be much appreciated
Modified by Cashieboi at 5:27 PM 2/10/2006
Old Feb 10, 2006 | 05:33 PM
97grnrs's Avatar
Default Re: My swap help z6 head (Cashieboi)
what distributor do u have? you will prob need a z6 one. if u search for vtec wiring you will find the connections u need to make , a grnd , and two wires to the ecu, not hard.get the y8 head gasket its thinner , will raise compression a lil .
Old Feb 10, 2006 | 06:56 PM
Cashieboi's Avatar
Default Re: My swap help z6 head (97grnrs)
stock distrubutor, ok the wires for ecu ic can figure out, but what as far as wire harness? do i need a obd conversion harness or what, if so which one because i have asked a few people and they say mines obd 2 then they say its obd 1 and im not shure which it is
Old Feb 10, 2006 | 08:36 PM
noboostedEGo's Avatar
If it's 92-95, it's obdI, if it's 96+, it's obdII.
Old Feb 10, 2006 | 09:33 PM
Cashieboi's Avatar
Default Re: My swap help z6 head (noboostedEGo)
hmmm ok so that means that the 96 del sol head (the one im puttin in car) is obd2 as well? so can i use the stock harness? another question, which wiring is required for the vtec, just all the ones connected to the soleniod or what?
Old Feb 10, 2006 | 09:47 PM
JamesV's Avatar
im doing this too!
Old Feb 10, 2006 | 10:48 PM
Cashieboi's Avatar
nice hehe alot of people are doing it now adays that cant afford a b series, not sayin ur poor or anything but yea haha
Old Feb 11, 2006 | 12:59 AM
JamesV's Avatar
yeah im broke and cant afford a b series
jchope
Sep 14, 2012 06:44 PM
foowitdaredek
Apr 25, 2007 08:05 PM
jdmcivicsi522
Apr 14, 2006 06:05 PM
Hatchdude
Jun 30, 2005 01:37 PM
