NRG Innovation Products: Quick Release Hubs, Locks, Hubs, Dampers, etc.
Old Feb 10, 2006 | 03:09 PM
JPRMOTOR.com's Avatar
Default NRG Innovation Products: Quick Release Hubs, Locks, Hubs, Dampers, etc.
2nd Generation Steering Release Kit $85 Shipped
2nd Generation Steering Release Kit Colors: Black, Silver, Red, & Blue
Product Description: 1st. Gen: This product was inspired using race car technology. By utiling quick release kits, drivers were more easily able to enter and exit their bucket seat equipped vehicles. We understand this and offer the quick release kt as a solution. Made from the best quality aluminum available, and thouroughly tested for smooth engagement, a snug fit, and repeat use, it does not get any better than the NRG Quick release.
Generation 1.5- Original chrome bodies and colored rings withe the additon of anti-scratch structure to increase shine life during heavy and repeated use.
2nd Gen: All the features of the above, including anti-scratch construction, self-locking mechanism, and bodies available in different colors as well.
For domestic cars and those with a five hole steering wheel, the five hole quick release has been developed.
Other Colors/Finishes:
A Variety of color combinations using different color rings and bodies. Bodies available in Black, Blue, Red and Chrome Other colors (2nd Gen only) Rings Available in red, blue, black chrome, silver, mat, silver, titanium, and black or silver carbon fiber.
Quick Release Short Hubs $85 Shipped
Quick Release Short Hubs Color/Finish: Black
Product Description: Another complement to our quick release steering kits. These units were designed specifically so that an aftermarket steering wheel installed with the quick release kit still mounts in the same location, not too close to the driver.
Product Features: Made from the highest quality aluminum. This product is designed utilizing one piece solid construction for the maxim in durablity and usability.
Other Colors/Finishes: Black
Steering Quick-Lock $95 shipped
Steering Quick-Lock Color/Finish: Black, Silver , Mat Silver
Product Description: A perfect complement to our quick release kits, this unit will deter any theif from stealing your vehicle. It is common knowledge that a quick release alone, although a good deterrent in itself, it is imperfect in that another wheel can simply be replaced. But with this unit, the column itself is secured, making replacement of wheel, or driving the vehicle virtually impossible.
Product Features: Ball-lock and key system. Tested throughly and made with the hightest quality and durable metals.
Other Colors/Finishes: Black, Silver, Mat Silver
Engine Damper $60 Shipped
Engine Damper Color/Finish: Titanium
Product Description: Engine Damper mounts in between your vehicle's engine block and firewall to effectively control horsepower and torque. Keep your motor supported as you slam through those gears while adding a nice show piece under the hood.
Addition Angles: None
Other Colors/Finishes: Titanium, Blue, Red & Silver
Hood Damper Kit $90 Shipped
Hood Damper Color/Finish: Chrome
Product Description: Often times, injury while working on a vehicle is caused by the hood falling on an individual. This product is offered for that purpose as well as a way to exhibit your under hood modifications. This unit allows the hood to remain up and stable even under high wind conditions. Thoroughly tested for repeated use, they are made with the highest quality aluminum case and steel shaft. Weighs in at only 200g on average, this is a must-have addition to any hood prop vehicle.
Product Features: Features: Easy to install and all hardware included. 2 Types aviailable, one for lightweight hoods, and another for standard hoods. Please specify when ordering.
Hydraulic damper assembly: oil filled shock light dampening formetal hood applications lift assist and slow decline features.
Material: Stainless steel w/ lightweight alloy shaft and casing with hydraulic oil seals end links for mounting points for durability and heat resistance.
Other Colors/Finishes (casing only): Silver
Liquid Filled Fuel Pressure Gauge $28 shipped
Color/Finish: Aluminum housing, Liquid Filled
Product Description: 1/8" NPT male fitting, displays fuel pressure up to +100psi and/or +8 bar. This gauge is a perfect addition to NRG's Adjustable Fuel Pressure Regulators
Other Colors/Finishes: None
Old Feb 13, 2006 | 02:36 PM
Default Re: NRG Innovation Products: Quick Release Hubs, Locks, Hubs, Dampers, etc. (JPRMOTOR.com)
Old Feb 18, 2006 | 01:42 PM
Container has Arrived!
Old Feb 19, 2006 | 02:21 AM
.xcalibur.'s Avatar
Can the Fuel Pressure gauge be used without the NRG regulator? CAn it be mounted on top of the fuel filter and do you have the fitting for that?
Old Feb 19, 2006 | 09:54 AM
DB8B20asic's Avatar
Default Re: (.xcalibur.)
Old Feb 20, 2006 | 04:42 PM
Default Re: (DB8B20asic)
Replied
Old Feb 21, 2006 | 11:48 AM
ChicagoMike's Avatar
Ordered my engine damper last week and it just showed up. Cant wait to mount it up! Thanks for your service, we'll do business again soon.
Old Feb 21, 2006 | 12:01 PM
Default Re: (RippinVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RippinVTEC &raquo;</TD></TR><TR><TD CLASS="quote">Ordered my engine damper last week and it just showed up. Cant wait to mount it up! Thanks for your service, we'll do business again soon.</TD></TR></TABLE>
Old Feb 21, 2006 | 01:28 PM
nickzed20's Avatar
Default Re: (JPRMOTOR.com)
im very interested in the quick release hub and lock system...
do you ship to canada? how much would that cost? these fit 92-95 civics? with a momo steering wheel? it will all bolt right up?
Old Feb 21, 2006 | 03:05 PM
Default Re: (nickzed20)
Replied
Old Feb 21, 2006 | 05:05 PM
nickzed20's Avatar
replied?
Old Feb 22, 2006 | 01:08 AM
zerovandez's Avatar
Do all the steering quick locks have the same keys for all?
Old Feb 22, 2006 | 05:46 PM
Default Re: (zerovandez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zerovandez &raquo;</TD></TR><TR><TD CLASS="quote">Do all the steering quick locks have the same keys for all?</TD></TR></TABLE>
No everyone is different
Old Feb 26, 2006 | 10:59 AM
Boriqua0555's Avatar
Do you have a hub and black quick realse in stock for a DC?
HPSpecialists
120
May 9, 2012 04:00 AM
Killspeed93
Aug 25, 2011 10:09 AM
jon o
Jul 12, 2010 09:10 PM
pwrofdrm
14
Feb 4, 2006 07:28 AM
