Throttle Body advice??? Skunk 2 vs BBL
Old Feb 10, 2006 | 01:08 PM
LudeAchris2001's Avatar
Default Throttle Body advice??? Skunk 2 vs BBL
I have a 01 lude with I/H/E and looking to put a throttle body on. Has anyone else installed one or have any say on this? HP gains any noticed? I purchased a STR throttle body and it was a POS didnt have the lines for the coolant and didnt hook up right. I was looking at the 68mm. I heard these mod doesnt do anything for the 5th gen prelude and its a waste of money??? I need some help here!!!
Old Feb 10, 2006 | 03:26 PM
The Weather Man's Avatar
yeah, Throttle bodies really don't help much with just basic boltons - actually, they might make you lose some HP.
Changing a TB is more effective on a car that reads air velociti rather than quantity. i.e - a car with a MAF sensor.
I'm going to suggest you wait a bit, alteast until you get cams and everything.
Old Feb 10, 2006 | 08:04 PM
mgags7's Avatar
i havent personally gotten proof...but brad at RLZ says 70mm or bigger for an h22....he reccomended 70mm for me....i have an str one....they dont use a fast idle thermal valve...i doubt you will find one that does, just loop those coolant lines....
Old Feb 10, 2006 | 09:05 PM
hu's Avatar
hu
Default Re: Throttle Body advice??? Skunk 2 vs BBL (LudeAchris2001)
STR is a great TB. I have the 70mm. Like Mgags said, loop the coolant.
Old Feb 10, 2006 | 09:31 PM
I guess its also recommended to have it port matched to the IM.
Old Feb 10, 2006 | 11:00 PM
mgags7's Avatar
yeah definitely port match it to the opening....its not tough....you can unbolt the plenum from the rest...
Old Feb 11, 2006 | 08:57 AM
jakeiscool's Avatar
Banned
http://www.maxbore.com
Old Feb 11, 2006 | 10:05 AM
Hawkze_2.3's Avatar
I'm using an Edelbrock 70mm (too big for now, I know...) and it's been great so far. It uses a Ford TPS which is much easier to come by than a Honda TPS...
Old Feb 11, 2006 | 04:33 PM
Rosko's Avatar
Default Re: Throttle Body advice??? Skunk 2 vs BBL (Hawkze_2.3)
all these 70mm's you guys are talking about are actually tapered correct? i built my own 70mm all the way through and machined the manifold to accept it which of course breaks through some casting walls into the IAC passages. I'm guessing these others will bolt up to a stock mani without modifications.
Lith ium
Mar 7, 2017 09:58 AM
bootlegtrader
Feb 5, 2006 09:04 AM
4DRmafia
Sep 3, 2005 10:17 AM
Que_Lude
Dec 24, 2004 02:12 PM
Shreik
Aug 3, 2003 01:08 AM
